Build tag decodeing
Build tag decodeing
Hey- I'm looking for some assistance to get my tag decoded. I've been searching all over the internet and haven't come up with much. I got the VIN figured out. I know she's a 1970 2 door holiday coupe built during the first week of December (I'm assuming 1969 for the 1970 model year) and came out of the Fremont plant. I've also figured out the engine is coded for 1977 to 1980. Still have to get the trans and rear end numbers.
Here's the info from the tag-
First line- ST 70-34257 BF 04297 BDY
Second line- TR 980 B80 19 B PNT
Third line- 12A 207048 760117
I've been able to figure out what each code represents (Body build number, color code, trim code etc...) but I can't seem to find what the actual codes are. And help would be greatly appreciated. Hopefully soomeone sa least can give me a line on where I can find this info. I just what to know what this car was when she rolled of the assembly line.
A number of people on here can help you and will likely chime in as soon as they see your post. If you haven't already seen it, you might also try this website:
http://automotivemileposts.com/oldsmobile/rpocodes.html
Hi, Welcome to the forum. I am new to it as well. Just decoded my tag last week. Here is a link to the codes on the Body tag. http://www.69olds.com/decode.html
I will let you decode it yourself though. It is more fun discovering what you have rather than having someone tell you.
Got any pictures?
Good luck!
Steve
Got any pictures?
Good luck!
Steve
Cowl Tag Help
I check your link and tried the other one as well and even tried www.oldsmobility.com
oldsmobility.com had the best info and mostly correct but still my cowl tag has somethings that no site can explain to me. Can anyone help me?
.....................General Motors Corporation
068 (there is a 1 stamped slightly above to the right of the 6 below)
ST 67-33867.................BF 00576......Body
TR....980................................2........ Paint
.......B80
J53406...........................140736
......................Body by Fischer
.......B80
I don't recall where I found the info below originally. I am mostly into 1966 so haven't verified references to 1965 in the stuff below. I have checked some of the info on 66s that I have seen.
GROUP 1
E = Tinted glass - All - (A01)
W = Tinted glass - Windshield only - (A02)
0 = Roof moldings for two-tone paint - For (D99)
S = Power Trunk - (A 91)
T = Power Seat - Bucket for sure – (A46). Bench maybe – (A4I) (1965)
T = Vinyl top (unconfirmed) (1966)
L = Hole & mounting plate for floor shift manual (1966)
X = Power windows - (A31) (1965)
X = Column shift auto (1966)
GROUP 2
K = Air Conditioning - (C60)
G = Console - (D55)
X = Floor mounted Automatic Transmission - used with (D55)
L = Floor 4spd - (M20 or M21)
B = Floor 3spd - (M12 or M14)
R = Rear Shelf Speaker - (U80)
T = Power Antenna - (U75)
A = Extra Foam Padding – Front Seat
P = Unconfirmed
H = Heater Delete (1966 only)
GROUP 3
D = Unconfirmed – only seen with interior accessory package.
W = Unconfirmed (1965)
W = Carpeting (F85 only) (1966)
GROUP 4
C = Chrome side window sill moldings – (B85)
H = Chrome upper “peak” body side moldings – (B84) (1965 only)
M = Moldings - door/window glass frame (F85 only) (1966)
V = 442 side trim – (W29) (1965)
D = Y68 side moldings
GROUP 5
F = Remote mirror (D33)
W = Deluxe front seat belts (A49)
Y = Deluxe front and rear seat belts (A39)
M = Unconfirmed
O = Unconfirmed – may be seatbelt delete (A62)
V = 442 trim (1966)
Z = Belts, shoulder harness (1966)
GROUP 1
GROUP 2
G = Console - (D55)
P = Unconfirmed
GROUP 3
GROUP 4
GROUP 5
M = Unconfirmed
V = 442 trim (1966)
Thanks everyone. I've been to the 69olds.com site, and most of my codes do not match. I also hit up the oldsmobility site, and same thing, most of the codes do not match. About all I can get from the tag itself is that the car came with chrome roof drip moldings. I'm more interested in the color, the original paint behind the door panaels is a copper/bronze color. Hopefully, I'll come across a build sheet for it as I start tesring things down this winter and cleaning the car up.
.......B80
.......B80
But those are just *accessory* codes and even in the applicable '64-'67 years, they were used at the Lansing and Framingham plants, but *not* at the Fremont plant.
Confusing enough? Basically need to look at each tag individually for answers.
You have a Cutlass Supreme Hardtop Coupe
Okay, 19 B is Ebony Black with a black top
980 Black interior.
Triple black! nice......
Kurt/wmachines brings up important points. Those who are enthusiastic about their cars should visit ebay and get a parts catalog and factory service manuals from the era. Trim, etc. codes can be found in them.
Body by Fisher, not Fischer.
The little hole at the bottom of 1966 cowl tags from Feb 66 on (to the left of Body by Fisher) indicate that the roof panel has reinforcements and threaded holes for shoulder belts.
I agree that the FIRST purchase any owner of an old car should make if they plan to keep it and/or work on it is the service manuals. They'll answer at least half the questions people typically have.
Thanks wmachine. I was told when I bought the car it was black, but I figured they were talking about the back primer I've been uncovering. Behind the driver's side door panel, it's a copper/bronze color, but that could be a replacement door. Triple black? I might have to consider that when it's time for paint. Thanks again!
sorry. i will start a new thread. I thought you'd prefer keeping the same type of question in the same thread.
hueveaj
April 25th, 2013 06:31 AM
wildwillie1981
April 24th, 2013 04:19 PM
