Brake drum question
Brake drum question
Have a 65 cutlass with drum brakes, I replaced the front drums by pressing off the old drums, but installing the new ones I can’t remember if I’m supposed to stake the new drum onto the hub or if it’s ok just to slip on like it does now?
seems like once the wheel is bolted on this would keep it all in place. Thoughts?
Thanks ahead of time
greg
greg
greg
greg
Some replacement drums are slip fit over the knurls on the lugs. Others are correct replacements and will require you to press the studs out anyway. Depends on which you have. The drum is located by the center bore, not the lugs. If you do have a press-fit drum, DO NOT try to brute force it over the lugs. You'll distort the drum.
Joe,
The new ones went on with no forcing I wasn’t sure about staking them so I didn’t. Just want to make sure I didn’t do anything wrong.
Drums are on and car stops great. Haven’t had to replace a front brake drum since the 70’s.
Yeah, you're fine. I've used a lot of slip-on drums over the years.
