Blower not working
Old Apr 2, 2022 | 09:54 AM
  #41
Pug Wrangler's Avatar
I's grounded at the mounting holes and the strap? I can't even find the other end of this thing.
Old Apr 2, 2022 | 10:05 AM
  #42
One end goes under a bolt on the back of the passengers side head. The other end bolts to the firewall, which I suspect is the end that is still intact.
That strap is the body (firewall) to engine ground. The ground path back to the battery is completed by the negative cable attached from the drivers front of the engine to the battery.
Old Apr 2, 2022 | 10:17 AM
  #43
Oh okay, it was dangling from the lower VR mounting bolt. I'll see if I can find one and find where the other end goes.
thanks
Old Apr 2, 2022 | 10:59 AM
  #44
Mine is mounted to the firewall below the VR.
Old Apr 2, 2022 | 04:56 PM
  #45
wish I could see the other end of that strap. I need to de-grease back there tomorrow so I can find the bolt.
thanks again
Old Apr 2, 2022 | 06:00 PM
  #46
Old Apr 3, 2022 | 05:43 AM
  #47
cool, it looked like it went past that bolt
Old Apr 11, 2022 | 05:12 PM
  #48
Well, that was fun. I found the hole in the head, but no bolt. Went through every bolt I could find around the garage, then bought a few different size bolts before before settling on a 3/8.
I have no idea why a pretty new strap was broken and the bolt was gone. anyways, got the new VR on finally, Can't test it yet because I pulled the alternator trying to get to a broken manifold bolt.
I wont get into that here.
Old Apr 18, 2022 | 10:37 AM
  #49
calidude's Avatar
Pulled my fender off over the weekend, was anticipating a bad blower motor but cleaning off the ground and purple power wire connection and the thing just started working. Having alternator woes too myself and there is a spaghetti of wiring that was bypassed too. My next project will be to tighten that up... the alternator bracketry for a 71 looks different than a 72
Old Apr 19, 2022 | 06:21 AM
  #50
Good luck with that!
steverw
Jul 5, 2017 07:27 PM
johnnyhawthorn
Mar 12, 2014 05:10 PM
Seff
Nov 30, 2013 08:18 AM
ljam02
May 25, 2012 09:25 PM
Olds64
Dec 12, 2009 02:49 PM
