bad connections
Old Nov 1, 2015 | 08:07 PM
neatolds's Avatar
bad connections
i am trying to fix my 1980 olds cutlass calais. the t top leaks so rain and water would come in.every time i would fix one connection another one would be bad. i have to fix every connection in the car would it be cheaper to replace the whole harness or keep on fixing things a little at a time. i also found the little ground wires under the dash were corroded and one was broken so the first thing i will do is change all the grounds and put a fuse in the main power line to the ac fan someone changed it out and didn't put a fuse in. what size fuse should i use? what size tires are supposed to be on the car there is 14 in tires on there now but it sits pretty low to the ground.
odddoylerules
Apr 21, 2014 07:54 AM
airmale
Nov 13, 2013 11:15 AM
68conv455
Oct 16, 2010 06:43 PM
bigoldscruiser
Dec 4, 2008 10:24 PM
esisson
Jul 5, 2008 08:12 PM
