Alternator Light
Old Apr 2, 2012 | 04:19 AM
bigfun64mo's Avatar
Alternator Light
I was going to drive my 72 cutlass to work this morning and when I started her up, the alternator light was on. I just replaced it last summer. It's possible it has gone bad again but doubt it. I am going to check the connection when I get home today. If those check out, I will pull it and have it checked. Any other things I should look at before going through all this? Thanks
Old Apr 2, 2012 | 05:11 AM
Lady72nRob71's Avatar
Check all connections at the batt, alt, and reg, belt tightness - the basics.
Using a voltmeter, take measurements at the battery with car stopped and then when running. When running it should be btwn 13 and 16V. If less, then the alt may have quit. Take it back to the store you got it and have them test it. Some of those remans are rebuilt poorly.
Old Apr 3, 2012 | 02:48 AM
bigfun64mo's Avatar
I checked all the connections. All appeared to be tight. So, I took off alternator off and had it checked. It checked out ok. I reinstalled it and the light is still on. Suggestions?
Old Apr 3, 2012 | 03:09 AM
Internally or externally regulated?
What is the voltage running and not running?
Old Apr 3, 2012 | 12:21 PM
mpolds's Avatar
1972 Olds Charging System
If your system has not been replaced with the "exciter set up" of an integral regulated alternator (originally -- 1973 & up), the 1972 is still
an EXTERNAL Voltage regulator system -- and the Voltage Regulators
fail frequently.........
I have them in stock four ways -- new solid state (they suck!) - $ 25,
N.O.S. USA - Made -- private label ---------------------------------- $ 39,
N.O.S. Standard (Best after market brand on planet) ------------- $ 49,
and ++ NEW ++ DELCO REMY -- ORIGINALS ---------------------- $ 85,
plus actual U P S Shipping from New York............
Best to call me ----- Craig -- 516 - 485 - 1935............
Old Apr 8, 2012 | 02:24 PM
bigfun64mo's Avatar
Well, I finally got around to replacing to voltage regulator. I also found the ground strap from the fire wall to the block was broken as well. I replaced that too. No Alternator light on. And all the radio issues of cutting in and out are gone! Thanks for the help guys.
Old Apr 8, 2012 | 04:21 PM
Looks like two big problems fixed at once. I love tales of success!
442mark
Sep 30, 2017 01:06 PM
w-31cutlass
Feb 18, 2014 01:11 PM
sykosoft
Feb 1, 2012 07:22 PM
442scotty
Jun 1, 2011 07:27 AM
REDROCKER-S
Oct 5, 2009 05:20 PM
