After market OAI hood for 72. What to look for?
I've always had my eye on eventually getting an OAI hood for my 1972 Cutlass Supreme with a 350. Although to have it fully functional would be nice, I would be happy to just have the look of it on my car.
I may have found what for what I think is a really great deal (just over $200). I wanted to come here to find out if there is anything I need to watch out for and find out what else I'll need.
1) I assume its probably a Tamraz hood. Seller says all he has done is a little work to make the contour fit his car. Never put it on because he found an original hood instead. These hoods good quality?
2) Light weight springs. Seller says it will come with the hood. Do I just replace the springs on my current hood hinges?
3) Hood pins. I assume I have to drive the holes in the hood. To get them to latch to anything, do I need to modify any other portion of my car?
4) Matching the paint. My car is pretty unique in color. Can paint shops match paint pretty easily and how much does it usually cost to paint just a hood.
5) Stripes? I guess if I want them I just need to stencil them on.
Anything else I should know or ask the guy? I really don't want to get a hood and then not be able to use it for anything.
Thanks again!
Here are some pics
Thanks again!
Here are some pics
Thanks again!
Here are some pics
Thanks again!
Here are some pics
2. Yes, use the light springs.
3. Buy the repo hood twist latches and bases. You will have to drill the hood to install these.
4. A good paint shop can come close. Cost??? They are all different.
5. I laid mine out by hand and painted myself. You can buy the vinyl stripes online.
Hope that helps.
1. Looks like my Glasstech. They never fit perfect and may warp a little from heat.
Hope that helps.
Hope that helps.
The current owner already made some relief cuts to match his aftermarket fenders. He guessed he had about 6-8 hours of work before it aligned to his car.
The main thing I'm worried about is if I get this hood, and too much was done to it as far as cuts go to make it fit my car. That and there is about a 2" x 2" crack on the top only. Is it worth it?
$200 I wouldn't think twice about it. The cheapest new all fiberglass ones are $600 and then still have to go through fitting/drilling etc. Hard to imagine the work you may need to make it fit yours would be more than a $600 one plus the fitting costs of that. Think with the look of your car I'd be tempted to not put stripes on it. If you do have them painted on instead of the stickers.
sx455raidercelticfan
July 6th, 2010 07:07 PM
