84 Cutlass Supreme rear butterfly window
Old Mar 18, 2013 | 08:31 AM
nealcali's Avatar
I have a 1984 Cutlass Supreme 4DR with powered rear door butterfly windows. The driver side rear window butterfly does not work and I need a new motor. Any info will be appreciated as to where to get a motor and also if the motor is the same as used in front doors.
Old Mar 18, 2013 | 03:34 PM
RetroRanger's Avatar
72 Olds CS
did you try taking the motor apart ?
many times the brushes wear out or get gummed up and a good cleaning will have you up and running again
Old Mar 18, 2013 | 04:17 PM
nealcali's Avatar
Thanks for the reply. I did not think the motor was repairable but I will try your suggestion.
Old Mar 27, 2013 | 04:43 AM
nealcali's Avatar
Old Mar 27, 2013 | 04:45 AM
nealcali's Avatar
As you suggested, I took the motor apart and cleaned/lubricated it. It now works OK. Thanks for your help RetroRanger.
Old Mar 27, 2013 | 05:40 AM
72 Olds CS
Good to know thanks for posting back.
I have "saved" a ton of stuff like that over the years by just taking it apart first
wyteon
Vista Cruiser & Wagons
Nov 30, 2018 11:33 AM
nolabigdawg
Oct 13, 2014 07:05 AM
f-85
Jan 16, 2012 06:10 AM
jrsixx
May 15, 2010 10:31 AM
vette442
Jun 8, 2009 11:14 AM
