70 supreme random questions
Old Feb 26, 2012 | 03:33 AM
Insom's Avatar
A couple questions about my car...
1. The battery was located in the trunk at one time which I thought was after market but it appears to be factory because it runs under the carpet that does appear to be all original along with the rest of the interior. Is that possible?
2. I also have a air valve behind the license plate????? What's that for?
1970 cutlass supreme
Any info would be appreciated, thanks.
Old Feb 26, 2012 | 05:38 AM
98 man's Avatar
Air valve behind license plate
Not sure about the battery cable to the trunk thing but the air valve behind the license plate was probably for air shocks. I have seen that several times.
w31man
Old Feb 26, 2012 | 06:20 AM
rocketraider's Avatar
Oldsdruid
Pretty sure that trunk kit was installed after the factory as the factory was not putting them in the trunk by that time, even on W-cars. A factory trunk mounted battery cable would have been run underneath the car, never thru the interior and especially not under the carpet. There's that little possibility of fire...
Were I you, I'd get it out of the interior and away from combustibles ASAP.
Old Feb 26, 2012 | 06:43 AM
droptopron's Avatar
delete
Agree on both points.
Old Feb 26, 2012 | 06:47 AM
1. 1966 and 67 W-30s were the only factory-installed trunk-mounted batteries, so no, it is not possible that yours was factory.
2. The factory air shocks used a fill valve attached to the bumper behind the license plate.
Old Feb 27, 2012 | 05:23 AM
Insom's Avatar
Thanks for the info. Looks like my car had air shocks and currently has a fire hazard
I plan on pulling the carpet up next month so should be interesting.
One more question...
What does factory sound proofing consists of?
Old Feb 27, 2012 | 07:13 AM
Asphalt-based sound deadener adhered to the metal (which should be soft, but is probably brittle like glass) and jute padding.
Old Feb 27, 2012 | 06:06 PM
Insom's Avatar
Ok I just have the jute padding and looking through the opg catalog I have 68 CS emblems on the doors of my interior that shouldn't be there??? Guessing someone did a some interior swapping or something.
How much of a difference will using double jute make on sound?
3" exhaust with spintech pro street.
Old Feb 27, 2012 | 06:15 PM
The asphalt insulation does most of the work, but works better soft than it does hard.
If yours is gone, you should replace it with an improved modern version, like DynaMat, FatMat, or one of the others.
It'll make a big difference.
Old Mar 4, 2012 | 02:25 PM
71cutla$$'s Avatar
i have a 71 cutlass supreme your battery should go on the driver side to the left of your radiator there "should" be a bracket made to hold the battery.
i also have the same air valve right by the gas filler cap under license plate maybe its stock or maybe it was just a common thing to do
Old Mar 4, 2012 | 03:27 PM
Both. It's just the place where it goes.
Old Mar 9, 2012 | 02:48 PM
blacksupreme's Avatar
I have a set of old air shocks on my Supreme. They still function.
66ninetyeightls
May 4, 2010 06:47 AM
lshlsh2
Apr 19, 2009 05:12 AM
Redog
Dec 3, 2008 08:48 AM
J-(Chicago)
Jan 26, 2008 03:07 PM
shirleys_cutsey_classic
Mar 9, 2006 01:10 PM
