70-72 Cutlass Swivel Bucket Seat Installation
Old Nov 20, 2015 | 11:57 AM
69442's Avatar
Has anyone ever installed swivel bucket seats from a '73-'77 Cutlass into a '70-'72 Cutlass, or even regular folding buckets w/ the built-in headrests? I'm wondering if they will bolt up or if the brackets don't line up and need fabrication?
Thanks in advance for any help,
Bob
Old Nov 20, 2015 | 12:42 PM
don71's Avatar
same but different
I once had the swivels in my 71. You will need to fab some spacers, or the seats will be tilted. This is not a bolt in, at least wasn't for me.
If you are a tall person, your head might rub on your head liner. Swivels sit higher.
I say try it. Remove your current seats and place the swivels in there and get a look at it. See what you think.
Old Nov 20, 2015 | 02:01 PM
lemoldsnut's Avatar
I had two different 73 cars one with the swivel seats and one with the standard buckets and was a much better ride and position in the car with the none swivel seats
Old Nov 20, 2015 | 02:11 PM
ELY442's Avatar
Bob
If you're going to install the swivel bucket seats, on the 70 Cutlass, the lap belt assembly that bolts down on the side will be in the way if you swivel out.
Old Nov 20, 2015 | 02:30 PM
69442's Avatar
Thanks for the replies. It sounds like the non-swivel might be the way to go.
Any thoughts on '71-'81 Camaro seats? They are similar in style and appearance. I like the look of the built-in headrests.
I have the factory buckets in my '72 Cutlass Supreme and I want to try something a little different in my '72 Cutlass 'S'.
Old Nov 21, 2015 | 07:25 AM
The only buckets that bolt in are the originals. Any others will require fabrication. If you must drill new mounting holes, be sure they go through the floor pan crossmembers, not just through the floorpan only. Otherwise, the bolts will eventually rip out, especially in an accident.
2blu442
Aug 24, 2014 01:51 PM
2blu442
Jan 9, 2013 11:07 AM
Draven
Oct 13, 2011 08:45 AM
twagor
Nov 11, 2010 07:46 PM
Driftr
Oct 26, 2009 08:59 PM
