70 350 rocket
okay so i just got a rebuilt 70 350 rocket and im going to switch over all the pulleys and everthing to the new engine and it should be fine then... im going to buy a new waterpump so ill just get a waterpump made for a 77 cutlass supreme with ac and i should be perfect correct
Good luck!
Don't be surprised if it is not.
That's what he said he was going to do in his post above. My point is that I've found that many vendors' catalog listings can be incorrect. It helps to know the actual height of the pump you want to avoid problems. You'll find many posts on this forum where people who swore they had a bracket issue actually had been given the wrong pump by the parts store.
That's the best way, either that or measure its height (accurately).
I bring the old part to the auto parts store whenever I can - every now and then, it saves me a lot of trouble.
cutlassKing
November 29th, 2010 03:05 PM
gscott819
July 28th, 2009 07:02 PM
esisson
May 22nd, 2008 07:47 PM
