69 cutlass S 350 Holley 4BBL
Old Feb 14, 2022 | 05:55 PM
lala5818's Avatar
I'm looking for recommendations. I have a 69 Cutlass S convertible with the original 350 and Turbo 350 tranny. I had a Holley 650 4BBL Model 4150 installed with an Edelbrock intake. Tranny was rebuilt but is original. I'm looking for a bracket that I can install on the Holley that will allow me to connect the kickdown cable and the throttle cable. Holley sells one but the slots for the cables are different sizes. Kickdown cable and throttle cable have the same connector size but Holley bracket 20-95 has different size slots. Any ideas?
Old Feb 14, 2022 | 06:20 PM
2blu442's Avatar
Many years ago I made this swap. I took the factory bracket and cut off the passenger side end. Since the space between the bolt holes of the carburetor are different on the square bore vs spread bore carbs it wouldn't bolt up. It worked for me, but looking back that is probably not the best idea as it only had one bolt holding it in place. But if you modify a factory bracket you know the cables for the throttle and kickdown would have correct places to clip into. Can you look at your quadrajet bracket to see if you can drill a new hole or weld on an extension to attach it to both rear bolts in the carb to intake studs?
Old Feb 14, 2022 | 06:51 PM
Why not connect the kick down cable to the gas pedal as Olds originally did?
Old Feb 14, 2022 | 09:56 PM
Put the cable thru the firewall, the way it’s suppose to be. No need to buy anything other than the correct cable, no fabrication, less headaches.
Old Feb 15, 2022 | 07:06 AM
If the car is an original TH350, the kickdown cable will already connect through the firewall to the accelerator pedal.
Old Feb 15, 2022 | 07:26 AM
2blu442's Avatar
Ah yeah, brain fart on my part. Was it the Chevy that has the kickdown cable attached to the carb Joe?
Old Feb 15, 2022 | 07:28 AM
Yes.
Old Feb 18, 2022 | 01:24 PM
lala5818's Avatar
Confused
I’m confused, so the kickdown cable does not attach here? Do you just attach it to the transmission dipstick and snake it over the rear of the engine and then through the firewall? Then attach it to the accelerator?
Old Feb 18, 2022 | 01:26 PM
Exactly as shown in the factory Chassis Service Manual.
Old Feb 18, 2022 | 01:34 PM
Also as shown in the PIM:
Old Feb 18, 2022 | 02:09 PM
2blu442's Avatar
Joe was quicker to located diagrams than I could take pictures! But I'll throw them up here anyway, this is a 1970 Cutlass but your 1969 should be a similar setup. If you don't have the correct gas pedal assembly with two places to attach cables I'll dig one of those out to get some photos. John
Two cables coming through the firewall
The lower one is the kickdown cable from the transmission. The upper is the throttle cable
This is the kickdown cable
Its attached to the passengerside of the transmission and runs up near the distributor cap, then over to the firewall hole.
Old Feb 18, 2022 | 02:45 PM
lala5818's Avatar
Y’all are awesome! Thank you for the help!
azehr
May 20, 2021 06:59 PM
coppertopgmc
Jun 24, 2020 04:39 AM
rhaberm
Apr 19, 2011 08:27 AM
rocketscientist
Oct 18, 2010 01:36 PM
rocketscientist
Mar 11, 2010 04:30 PM
