'69 Cutlass 455 HELP!!!!!
Old Jul 29, 2006 | 05:51 AM
briancrittendonii's Avatar
Question '69 Cutlass 455 HELP!!!!!
I can get a newer 455 but all the research I have done has concluded that the 1970 and older models are the best for H.P... Should I go for the newer or wait for the older. Also what can be done for adding extra performance and stopping prob's with cam. Are there any other common prob's I should be aware of?? This motor will go into my 69 Cutlass used for mostly street but WILL GO TO THE TRACK AT LEAST ONE TIME BEFORE I DIE!!!!!!!!!!!
any info will help please give me anything you got Thanks ahead of time.
Old Aug 5, 2006 | 03:06 PM
mcutlass1969's Avatar
455's
Here is what I did. I purchased a 455 out of a 76 Toronado. Had it bored out 30 over and put the Edelbrock Power Pack kit with it and performace pistons. Believe me it has plenty of HP on the Street. Now for the things to watch out for. Make sure the Crank can still be machined. I had to buy another 455 to get a good crank. The factory 455 cranks are like gold and are hard to find. You can get one from Mondello Performance but it will cost you.
Mike
455's
Mike
455's
Mike
455's
Mike
455's
Mike
455's
Mike
Old Aug 5, 2006 | 03:07 PM
sorry PC issues on the reply.
Old Aug 5, 2006 | 07:55 PM
orange442's Avatar
455
Earlier 455's had a higher nickel content in the casting(look on back of block for F1.F2, etc.) the smaller the number next to the F the higher the nickel content. They also usually had nodular cranks marked by an N or CN cast into one of the throws on the crank. Any year 455 can be built to run strong, the earlier stuff is just inherantly stronger and longer lasting.
Old Aug 5, 2006 | 10:59 PM
texasred's Avatar
Tom Servo's Stunt Double
Orange,
Not meaning to steal the thread, but is that true for small blocks (350) also? It's GREAT info!
C.J.
Old Aug 6, 2006 | 03:38 AM
Dave H's Avatar
Stay away from the 77-79 350's. They had windowed main webs like the 403's and flex a lot more if you lean on them a little with modifications. They also have the less robust metallurgy. 68-72 blocks are still a dime a dozen in most areas of the country, and nodular "N" cranks aren't that rare either.
Old Aug 6, 2006 | 09:26 AM
orange442's Avatar
Yes, the 350's do follow the same basic guidelines in nickel content and nodular cranks. But, unlike the ultra-rare forged steel 455 cranks, you can use a 330 crank in a 350 and they are all forged steel and not near as hard to find. They have the same stroke and journal size as a 350 and you will need to retain the 330 flywheel(different bolt pattern) and balancer. The only other way to have a stronger 350 block is to convert a 350 diesel block to gas use.
nolabigdawg
Nov 16, 2014 06:45 PM
Hercules
Nov 18, 2013 01:07 PM
MJAKS462
Apr 15, 2010 02:34 PM
71cutlasssx
Jan 14, 2010 01:25 PM
egknz
Jul 21, 2009 01:09 PM
