69 350
Old Feb 27, 2010 | 11:15 PM
cutty's Avatar
69 350
hey guys i just bought 69 350 rocket. need some insight about the motor an who has one any tips too look out for.. it's engine code 395558 2 with #8 X heads, also what carb should i go with 600 750 ?
Old Feb 27, 2010 | 11:29 PM
svnt442's Avatar
How do you know it's a 69? Did you get the stamping off the block below #1 spark plug?
I ask because #8 heads are 73-76 heads and 69 heads should be #5.
Old Feb 27, 2010 | 11:40 PM
cutty's Avatar
well the 395558 2 is above the waterpump an not sure if about to stamp but they could have just switched heads? on the back of the block it says 2 an F i think if that helps any the intake has #10 not sure what that means
Old Feb 28, 2010 | 01:26 AM
svnt442's Avatar
That casting number behind the water pump is the same from 1968-1976 so that is no help. What I'm talking about is a machined pad that is located on the side of the block below the head under #1 spark plug.
The stamping you are looking for will look something like this:
39MXXXXXX
3 = Oldsmobile
9 = model year (early 350s 8,9,0,1,2,3,4,5,6 in that order)
M = production facility (Lansing in this case)
XXXXXX = last 6 of the VIN from the car the engine came out of
If per chance the pad is blank then you have a warranty block that was never stamped by the mechanic that replaced it and should have been and thus no way to prove what year the block actually is.
Old Feb 28, 2010 | 09:30 AM
cutty's Avatar
ok this is what i got kinda hard to see but 38M45783 couldnt see the last number
Old Feb 28, 2010 | 10:30 AM
If that second digit is in fact an "8" and not a "9", then it's a '68 block.
Old Feb 28, 2010 | 04:28 PM
Are you sure the second digit is an 8 and not a 3 (which would indicate 1973)? If it's really an 8, the heads have been swapped at some point.
Old Feb 28, 2010 | 09:19 PM
cutty's Avatar
yep it's an 8 see that clear an prolly heads just switched .. what's wrong with the #8's?
Old Mar 1, 2010 | 07:52 AM
Much larger chambers with resulting lower compression. If this 1968 block was a high compression motor with shallow dishes in the pistons, someone may have installed the no. 8 heads to lower compression so it would run on current gasoline.
Old Mar 1, 2010 | 11:06 PM
cutty's Avatar
ohhh....that could be then the motor rebuilt but not sure with anything what cam, pistons, the guy i bought it from his friend had it built
falconsfan
May 14, 2015 05:47 AM
dharlett
Sep 23, 2009 03:30 PM
Jokers69
Oct 5, 2006 03:00 AM
<Eddie>
Nov 1, 2005 07:30 PM
