'68 vs. '69 instrument panel
Old October 12th, 2010, 09:45 AM
Mike H.'s Avatar
Does anyone know if the '68 and '69 plastic instrument panel is the same. Like most, mine was cut around the radio when the previous owner put in a cassette player. Anyone got one for sale?
Mike
Mike H. is offline
Old October 12th, 2010, 10:52 AM
Mike
The plastic parts are different between 68 and 69. 68 has the ignition switch in the dash (and thus there is a hole for it), 69 has it on the steering column.
joe_padavano is offline
Old October 12th, 2010, 10:54 AM
Wait, I just re-read your question. The radio plate is a bolt-in part. If the non-stock cutout is confined to the radio plate, you can just swap that piece, not the whole dash. Note that the radio plate is actually die cast metal in those years, and 68/69 are the same.
Old October 12th, 2010, 12:02 PM
Mike H.'s Avatar
Joe,
Actually, you had it right the first time. I was referring to the big plastic piece that is attached to the dash. I believe it encompasses the radio and switches below the gauges. Sounds like its a one year only piece. I'll keep looking for one. Thanks for the reply.
Mike
Mike H. is offline
Old October 12th, 2010, 12:12 PM
Joe,
Mike
I know what you were referring to, Mike, but in the 68/69 cars the radio mounts above the ash tray. The plate that holds the radio is a separate bolt-on part that can be replaced without replacing the entire plastic lower portion. Now, if the previous owner hacked the plastic portion, like cut out the ash tray to mount a large aftermarket radio or something, then you do need the whole plastic part. If the damage is just on the OEM radio mounting plate, however, then all you need is that small piece, which is common to both years.
rroth01
December 23rd, 2023 04:35 AM
rroth01
March 1st, 2009 06:04 PM
John G. Nelson
December 9th, 2008 08:52 PM
1966Dynamic88
October 20th, 2006 07:35 PM
1966Dynamic88
May 9th, 2006 11:51 AM
Quick Reply: '68 vs. '69 instrument panel
