68 Cutlass 12 bolt rear end question
Old Dec 3, 2016 | 05:29 PM
1970f85's Avatar
My son has a 68 Cutlass with the 12 bolt cover, non-posi 273 gears. He wants posi with 355 or 373 gears...which they don't have much for these rear ends I've noticed. Whats the best choice, get a 68-72 Chevelle 12 bolt rearend, it should bolt right in, what about driveshaft length as he just had a $450 driveshaft made for his car.
Old Dec 3, 2016 | 10:07 PM
oldsfromyell's Avatar
12 bolt chev differential will require drive line to be shortened to replace the Olds 12 bolt. I would look for a 71-72 8.5 10 bolt from a Cutlass. It will have the bolt in axles and uses corporate 8.5 10 bolt carrier and gears. I think you can use the same driveshaft you have with the 10 bolt not 100% sure.
Old Dec 4, 2016 | 10:15 AM
If you keep the O-Type, you are limited to 3.42, 3.90, and 4.10 for new ring and pinion gears. For a posi diff, either used GM O-Type (671 or 588 casting numbers) or new machined Ford 8.8 carriers are the only things I am aware of.
Swapping to a 71-72 corporate 8.5 inch 10 bolt opens up the range of gear ratios and posi choices.
Old Dec 5, 2016 | 06:56 AM
oldsmobiledave's Avatar
no 2.73
2.73 gears were never offered. It is a 2.78.
You can get carriers & appropriate gears from several vendors who are board members. Rebuilding a rear end is not cheap. You have to pay to play.
Old Feb 6, 2017 | 02:00 PM
distributorguy's Avatar
I found a tight GTO 3.55 posi on CL for $500 locally. Not a big deal to install. Bolts right in. Takes all the same brake components.
Old Feb 6, 2017 | 03:49 PM
Fyi
Are you talking about an 8.2" 10 bolt? If so you paid a fair price. They are not strong and don't like sticky tires.
If that is a 12 bolt Chevy 3.55 from a 71-72 455 HO car then you stole it.
Old Feb 6, 2017 | 03:53 PM
Agreed. My brother-in-law has the original 3.55 cone style posi behind his GTO and it has held up for years behind a stout engine, but he also has tires with almost no traction. It's one of those differentials with a split case and 10 bolts holding the halves together so it has some inherent weaknesses.
Old Feb 6, 2017 | 04:36 PM
1970greensupreme's Avatar
if it's an auto even the 8.2 should hold up fairly well
monzaz
Oct 26, 2020 07:05 PM
rcdynamic88
Drivetrain/Differentials
Apr 7, 2015 11:21 AM
350TurBRO
Sep 12, 2014 11:52 AM
69Cutlss
Jun 20, 2014 09:30 PM
HitTheHole
Aug 11, 2013 09:17 AM
