67 cutlass supreme, purple wire
Old Oct 10, 2021 | 01:31 PM
irydasteelhorse's Avatar
67 cutlass supreme, next to the horn relay is a plug in with one purple wire, and one yellow. anyone know what those two wires are for? thanks in advance
Old Oct 10, 2021 | 02:29 PM
Sounds like power source for starter and ignition-while-cranking, respectively. There's a good wiring schematic, in color, in the chassis service manual for 67.
Old Oct 10, 2021 | 03:16 PM
this is the set of wires. you must be correct, cuz when i would wiggle em, id either get a stall or a no start. i appreciate your time. i think i need to clean this plug well, and make sure it stays plugged, it was half way undone
Old Oct 10, 2021 | 03:29 PM
Originally Posted by irydasteelhorse
...i think i need to clean this plug well...
Buy a 1967 CSM.
Old Oct 10, 2021 | 03:33 PM
I don’t know what the purple wire goes to, but the red wires power everything inside the cabin to include power to the ignition switch. If wiggling that connection is causing issues, you will probably find yourself broken down on the side of the road. You need to install a junction block and put terminals on the wire ends.
Old Oct 10, 2021 | 03:36 PM
66SportCoupe's Avatar
Purple wire comes from the neutral safety switch and goes to the start side of the starter solenoid.
Old Oct 10, 2021 | 04:47 PM
thank you gentlemen. exactly the issues im having. i will go thru this with a fine tooth comb.
Old Oct 10, 2021 | 04:51 PM
Can't stress this enough. If you're going to go through it w/ a fine tooth comb - it's essential you own the CSM and the original wiring diagram. Plenty of them out there starting @ $15 - grab one.
https://www.ebay.com/sch/i.html?_fro...anual&_sacat=0
Old Oct 10, 2021 | 04:55 PM
The purple wire for the nss originates at the ign switch then goes through the nss, then through the bulkhead connector, and then straight to the starter S terminal. It did not connect to the horn relay.
Old Oct 10, 2021 | 08:52 PM
danktx's Avatar
I have had no start problems myself. I found the problem to be dirty contacts in the plug shown in the picture. I cleaned the connectors in the plug and have not had a problem since.
brianbeez67
Sep 2, 2021 05:37 AM
JCDC
Oct 16, 2020 02:04 PM
Roger60
Jan 12, 2017 07:14 AM
ctrain22
Sep 16, 2009 05:27 AM
