65 Trunk Lid adjustment
Old Dec 28, 2010 | 06:36 AM
Rdrokit's Avatar
I started a thread in the Body & Paint section but thought I would put it here also.
As you can see by the photo my trunk lid on my 65 Cutlass sits too high on one side. Is there an adjustment and how do I do it if there is.
Thanks,
rokit
Old Dec 28, 2010 | 07:23 AM
stan 65 cutlass's Avatar
i believe theres supposed to be a 1/4" spacer between the hinge or something. but your lid could be twisted also
Old Dec 28, 2010 | 08:19 AM
Run to Rund's Avatar
On that side, put alignment shims under the bolt to the rear of the car. The factory shim was a little different in shape, but front end suspension alignment shims are easy to find.
Old Jan 4, 2011 | 03:44 PM
nonhog's Avatar
Registered car nut
This might be helpful.
V
http://www.hotrodders.com/forum/trun...Lid+adjustment
Old Jan 5, 2011 | 12:59 AM
Rdrokit's Avatar
nonhog, thanks a very helpful thread. Since I live in Thailand I have limited access to parts. Can I use washers for shims?
Old Jan 10, 2011 | 12:15 AM
Rdrokit's Avatar
I want to thank you guys for the helpful info. I used 2 washers as shims and as you can see it worked.
Thanks again,
rokit
shamusj
Apr 7, 2018 08:10 AM
2blu442
Oct 18, 2014 04:55 PM
Bitburger
Mar 17, 2012 04:04 AM
Rdrokit
Body work
Dec 28, 2010 06:30 AM
Allan R
Nov 20, 2009 08:54 PM
