'65 330 motor
Old Aug 13, 2020 | 05:48 AM
llcooljc's Avatar
'65 330 motor
I have a '65 cutlass convertible that someday I hope to have the time to restore. I have decided that I will be putting new technology into it for the motor/trans.
That said, are they worth anything? At this point they are just sitting around outside the car taking space and I'd damn near give it away to someone who wanted to use them.
A rebuild would definitely be needed. The car hadn't been started in almost 20 years when I got it a few years ago. It is not locked up.
Thoughts?
Old Aug 13, 2020 | 06:53 AM
Old Aug 13, 2020 | 09:00 PM
edzolz's Avatar
Restore and putting new technology don't go together.
Old Aug 14, 2020 | 05:26 AM
Rocket Launcher's Avatar
If you keep an Olds engine in it, your resale value and pool of prospective buyers will be a lot larger.
Old Aug 14, 2020 | 07:26 AM
69 Ragtop's Avatar
All of this is from my weak memory. We used to race a '64 Cutlass 330 convertible in the late sixties in, I believe C/SA (before the classes changed). It had the Jetaway 2-speed trans, Casler slicks and headers and turned in the low 14s. Other than that it was stock. We were unfortunate to be in a class with a local '59 Plymouth 383 with dual quad ram induction (where the carbs sat over the shocks!) called "The Spoiler" that ran on the National Record, around 13.80s. He won stock eliminator about every week and we won 2nd place in class . Bottom line? The engine performs respectably, even with the Jetaway.
Old Aug 14, 2020 | 07:33 AM
llcooljc's Avatar
edzolz - thanks for the response. VERY helpful
Rocket Launcher - Yep. I've decided that's not a deal breaker for me with this car
At some point the original 2 speed jetaway was replaced with a 3 speed.
Old Aug 14, 2020 | 09:48 AM
Bfg's Avatar
Bfg
That garbage can will haul A$$!
Old Aug 23, 2020 | 09:18 PM
cjsdad's Avatar
Multi-port EFI'd, roller-cammed, aluminum-headed, 4-inch stroked, 4-speed OD automatic, OLDS power! If it was easy, everyone would do it!
Old Aug 24, 2020 | 06:34 PM
NTXOlds's Avatar
Very nice. Have you had it on a dyno? Any idea of the power? What about fuel economy?
Old Aug 25, 2020 | 05:36 AM
cjsdad's Avatar
I live at 7000 ft elevation so these numbers may not be available at this altitude.
Old Aug 25, 2020 | 06:23 AM
NTXOlds's Avatar
Wow! Those are fantastic numbers! I bet it is a blast to drive.
If I ever build one myself, I know who to ask for suggestions.
Old Aug 25, 2020 | 08:04 PM
cjsdad's Avatar
I haven't been able to drive it yet. I was slammed in the face by life at about the same time the engine was delivered. I am getting very close though. If you want to know a bit more about it, here is a link to the engine build thread. It was built by Mark Remmell, AKA Cutlassefi here on the forum.
https://classicoldsmobile.com/forums...s-3/im-128573/
Old Aug 26, 2020 | 05:05 AM
NTXOlds's Avatar
Thanks! I hope life gives you a break and allows you to drive this soon.
Old Aug 26, 2020 | 05:36 AM
35tac's Avatar
Joe, I like that. It's funny, well done.
Wayne
slantflat
Apr 7, 2018 06:10 PM
ferndaleflyer
Feb 15, 2014 12:23 PM
HonestDave
Sep 15, 2013 01:52 PM
lilhow
Jan 13, 2013 06:55 AM
Mikes65
Sep 4, 2012 06:14 PM
