350 SWAP TO A 425
Old Jun 23, 2008 | 06:26 PM
ZASX's Avatar
Question 350 SWAP TO A 425
I NEED SOME HELP ON WHAT I NEED TO CHANGE LIKE RADATOR, DRIVE SHAFT ,HEADERS? ,MUCH THANKS
Old Jun 24, 2008 | 04:56 AM
Oldsguy's Avatar
Past Administrator
What car? There are quite a few threads about 350 to 455 swaps, you may find some pertinant information in those if they were for a similar bodied car.
Old Jun 24, 2008 | 06:07 AM
ZASX's Avatar
I`M PUTTING THE 425 in the 72 cutlass
Old Jun 24, 2008 | 06:11 AM
Oldsguy's Avatar
Past Administrator
If you car keeping the same transmission you won't have to change the drive shaft. Headers shouldn't be a problem either. Radiator might need to be changed though, not sure.
Old Jun 24, 2008 | 06:42 AM
Oldsproject's Avatar
65 post sport coupe w/425
I did a 330 - 425 swap in a 65 F85 with little issues. Headers on this car were really tight though. Only real change required was the radiator. Everything else fits fine. Another clearance issue I have (not related to Big Block swap) is the hood clearance between the air cleaner (tight to the hood). This was caused by the performer intake and height of the new carb combined with the edelbrook air cleaner I chose. Not the swap. Use the 350 motor mounts. On mine, tranny (TH350), driveline, etc all fit fine. Goodluck
Old Jun 24, 2008 | 06:44 AM
I actually did exactly this swap on my first car (68 Vista) when I was young and stupid (shortly after the earth cooled). This was my first exposure to the different crank flange bolt patterns on Olds motors. Here's a tip - DO NOT simply elongate the holes in the 350 flexplate to fit the 425.
Do NOT ask me how I know this...
You probably know to simply bolt the 350 motor mounts to the 425. Yes, you'll need the correct flexplate/flywheel. The 350 starter will bolt up but you may want to invest in a high-torque version at some point. You'll need the correct exhaust manifolds or headers for a big block. You can bolt the 350 accessory brackets to the 425, but you'll need to transfer the water pump and pulleys as well (or at least verify that the water pump on the 425 has the same height as the one on the 350. If your current radiator is a 3-row, you MIGHT squeak by, but I'd go with a four row.
Old Jun 24, 2008 | 10:06 AM
BILL DEMMER's Avatar
Just the facts...
i did a 330 to 425 swap on a '67 cutlass. i had the delta donor car, too.
i used the delta's radiator after swapping the right side saddles.
you're also going to want to use the thicker battery cables that a bbo uses. you're going to want to get a carb. that's set up for the 425, with the '72 throttle linkage connection.
bill
Old Jun 24, 2008 | 11:56 AM
ZASX's Avatar
will the original drive shaft that came with the 350 fit with the 425 & a 400 tranny in my 72 cutlass
Old Jun 24, 2008 | 12:06 PM
No. The TH400 is longer (requiring a shorter driveshaft) and the yoke is different.
Old Jun 24, 2008 | 12:07 PM
Oldsguy's Avatar
Past Administrator
Not if the TH400 has a long tail shaft.
Old Jun 25, 2008 | 06:02 PM
ZASX's Avatar
THANKS AGAIN FOR THE INFO YOU GUYS ARE SAVING ME TONS OF TIME & MONEY
Old Jun 26, 2008 | 11:57 AM
I assume you meant if the original TH350 was a long tail shaft. That's true, but if it's the original trans in that A-body, it's short.
Old Jun 27, 2008 | 01:09 PM
olds4life's Avatar
is the 350 a good running one. if so i'm interested if within two hours of me (st. louis).
Old Jun 28, 2008 | 02:09 PM
ZASX's Avatar
350
sold it, ran great but wanted more hp .
Old Jul 2, 2008 | 05:05 AM
Rallye469's Avatar
I did the same swap too...
When it came time for the driveshaft I just measured it all up
and went to my salvage yard.
They kept a pile of shafts there a mile high.
You will need a TH400 yoke.
steve walker
Dec 17, 2019 12:32 PM
falconsfan
May 14, 2015 05:47 AM
oldrelics
Non-Olds Engines
Jun 12, 2014 07:09 PM
<maxone>
Nov 28, 2008 11:57 PM
SUGRUE
Feb 16, 2007 08:08 PM
