1988 olds cutlass supreme sl pcv
Old February 17th, 2018, 12:27 PM
Brian Disney's Avatar
Recently was given a 88 Olds Cutlass Supreme SL FWD from my grandma. I can't find the correct PCV valve and PCV hose for this car. Any help would be appreciated. I have attached pictures of what the setup looks like.
Brian Disney is offline
Old February 19th, 2018, 05:05 AM
69 Ragtop's Avatar
NAPA shows 4, and some grommets:
https://www.napaonline.com/en/search...tForm-savedveh
One of them might fit yours but, as we know, the parts game gets more and more complicated as the years go by. Just because the configuration isn't exact doesn't mean it won't work.
69 Ragtop is offline
Old February 19th, 2018, 09:30 AM
Thank you so much for looking into this! When I click the NAPA link I get a list of 600+ parts, did you happen to see the P#?
Thanks Again!
Brian
Old February 19th, 2018, 01:43 PM
69 Ragtop's Avatar
Just click on the link I posted and you'll see the valves.
If that doesn't work, go to "napaonline.com." Put in the year, make and model of your Olds. Then in the search box type "PVC valve". That'll get you there.
BOPMan
June 14th, 2015 04:35 AM
PalmSpringsOlds
May 22nd, 2010 06:49 AM
ny43
August 5th, 2008 06:18 AM
ny43
May 31st, 2008 11:47 AM
<kllorbekld>
Drivetrain/Differentials
February 9th, 2007 06:11 PM
Quick Reply: 1988 olds cutlass supreme sl pcv
