1976 Cutlass Shift Cable Problems
Old Feb 22, 2017 | 03:31 PM
Salon 76's Avatar
I need to replace the console shift cable on my 76 Cutlass but I haven't had any luck finding a replacement cable. The eyelet to eyelet length of the cable is 30".
Does anyone have any suggestions?
Thanks - Dave Morris
Old Feb 22, 2017 | 04:56 PM
RetroRanger's Avatar
72 Olds CS
idk if this is the right one but maybe
http://www.ebay.com/itm/73-74-75-76-...-/231289315827
Old Feb 22, 2017 | 04:59 PM
CRUZN 66's Avatar
Olds Fever
The GM part number for the cable you need is 416753... It should fit from 73 thru 76 (77??)... It is discontinued, but maybe a GM dealer can try a parts locator search... It's a long shot, but you never know what an old dealership might have on the shelf...
Old Feb 23, 2017 | 05:31 PM
Salon 76's Avatar
Thanks for the info!
Dave
Old Mar 18, 2017 | 05:36 AM
Salon 76's Avatar
The Ebay cable looked to be the perfect solution but upon installation I was unable to accommodate the additional 1" length (31" vs 30") without binding.
A friend fabricated a stainless steel sleeve to provide support to the damaged portion of the original cable and this solution is working at this time.
Other than a major exhaust leak at the catalytic converter, everything works well and my 76 Salon is back on the road after 14 years.
Old Mar 18, 2017 | 02:46 PM
442fanatic's Avatar
I think you can get those through Rock Auto. I bought my Hurst shifter cable for the 76 through them. 75 hurst share the same console with 76/77 but with the opening for the Hurst dual gate.
Back to the point, I believe they have a stock replacement cable.
Alex
Old Mar 18, 2017 | 04:10 PM
Salon 76's Avatar
Alex
I wish that they did but I haven't been able to find one in their online catalog. Any idea what sub-section the cable is listed in?
Old Mar 18, 2017 | 04:32 PM
76olds's Avatar
Hookers under Hood
Have you tried LOKAR ? I'm sure they would be pricey but that may be an option. I have the LOKAR catalogue ill take a look.
Have you checked out the new http//73-77oldsmobile.freeforums.net/ site ? Maybe someone would have an extra shifter cable over ther.
Good to hear you got er' running and back on the road after sitting for 14 years !!
I hope this helps
Eric
Old Mar 18, 2017 | 04:57 PM
76olds's Avatar
Hookers under Hood
Dave,
Lokar shows console shifter cables for TH-350 and the TH-400.
It appears as thou they only come in lengths of 6-8-12-16 and 23" .
The column shifter cables go up to 32" .
The part number for the 23" is ATS6350A
Eric
Old Mar 19, 2017 | 03:51 AM
Salon 76's Avatar
Eric - Thanks for the input! From my experience with the other cable, I'll keep looking for the 30" length. Luckily for me the cable itself is not damaged, just the outer housing which is not under stress in this application.
Dave
Old Apr 20, 2017 | 06:55 AM
442fanatic's Avatar
Might be a bit late, but here is one on ebay even with the tunnel grommet
http://www.ebay.com/itm/73-74-75-76-...IsRdiA&vxp=mtr
Old Apr 20, 2017 | 09:16 AM
Salon 76's Avatar
That is actually the same cable as I purchased. The 31" length was the problem. If it was 30" then it would have worked well.
Old Apr 20, 2017 | 10:17 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
The factory cable is available through many sources. It was used on many other GM cars so look to others such as Camaro, Pontiac Firebird/TransAm.
Old Apr 21, 2017 | 05:00 AM
Salon 76's Avatar
The key is to find one that is 30" long. I have looked at a number of shift cables online but have yet to find one that is the correct length.
Old May 9, 2017 | 07:01 PM
Paladin31's Avatar
Shifter Cables
Still looking for one of these then?
Brett
Old May 10, 2017 | 03:57 AM
Salon 76's Avatar
Brett
Now that is a bunch of shift cables! Actually, First77 pointed me to a NOS cable on Ebay and now I have it.
You wouldn't happen to have a dual exhaust crossmember, would you?
Dave
Old May 10, 2017 | 05:02 PM
svnt442's Avatar
Dave
You'll have to get one from a 73 or 74 and then drill new holes in your frame for it to fit.
Old May 10, 2017 | 06:01 PM
Paladin31's Avatar
X member
Sorry Dave I don't.
Brett
chasman414
Jun 25, 2020 07:05 AM
rootney
Jun 27, 2014 11:30 AM
dmberendsen
Apr 10, 2013 03:18 PM
ctrain22
Sep 7, 2009 10:54 AM
