1972 OAI hood pin bracket question
Old Jan 13, 2020 | 03:55 PM
Minnesotajeff's Avatar
1972 model, the service manual indicates all 3 bolt holes should be utilized to mount these brackets. Per the attached photo, there are holes in place for the center and right mounting hole but not the left. And only 2 bolts were supplied with each bracket.
1. should I drill a hole for the left (inner) mounting point and secure that also?
2. is the rubber hood bumper on the left in the photo supposed to stay in it’s original location or is that possibly supposed to be moved to the center mounting spot on the bracket and that is why they only send 2 bolts with each bracket?
3. does that original rubber hood bumper stay in place or get removed completely with the OAI?
thanks guys
Old Jan 13, 2020 | 06:46 PM
BSiegPaint's Avatar
Mine is a '70 - not sure if there is a difference in where your hood bumper is supposed to be...?
Old Jan 13, 2020 | 08:00 PM
70Post's Avatar
Leave your hood bumpers where they are....that is the correct location for '72 - even with the OAI hood (and maybe 71...don't know for sure). The kit you bought "assumes" you have a '70 car (or more likely, they are too cheap to include extra bolts/nuts).
Maybe someone with a '72 Assembly Manual can post of pic of the appropriate page which will show what is done with each hole on the brackets.
kbdecatur
Feb 10, 2019 12:20 PM
pencetaylor
Nov 13, 2015 08:09 PM
nofiveo
Body work
Jul 10, 2012 06:53 PM
FIJIBLUE72
May 21, 2009 04:14 PM
