1972 Cutlass S with 442 grille ? emblem
Old Jun 13, 2013 | 08:35 PM
Dangerbird's Avatar
1971 Cutlass S installing 1971 442 grilles, want rid of the 442 emblem. has anyone done this? what emblem olds or cutlass will cover the 442 holes?
Old Jun 14, 2013 | 08:01 AM
Since those grilles only came with the 442 emblem, I doubt anything else will be close.
Old Jun 14, 2013 | 09:24 AM
jpc647's Avatar
I thought there was a "350" one that would.
Old Jun 14, 2013 | 09:36 AM
Not that was ever used on an Oldsmobile. If by some miracle there is another emblem that fits, it's purely coincidental.
Old Jun 14, 2013 | 09:43 AM
NHolds's Avatar
Nothing else fits perfectly. You would have to modify an emblem, or modify the grille. I plan to use an old Cutlass emblem and cut the studs off. Then double side tape it to the grille.
Old Jun 14, 2013 | 11:09 AM
Dangerbird's Avatar
Yes, that's what I plan to do, modify grille or emblem. The 1971 fender script "Cutlass" nearly covers as does the Oldsmobile emblem out of the S grille. I don't want to just start buying emblems to get one to fit. The 350 is a good idea but I would have to find a Olds 350 emblem.
Old Jun 14, 2013 | 12:11 PM
nofiveo's Avatar
I'm going to use the "OLDSMOBILE" emblem that was in my "S" Grille originally. It had a black backing plate behind it that mostly covers the 442 holes.
Old Jun 14, 2013 | 12:13 PM
Dangerbird's Avatar
Yes I was thinking that also, mine didn't have a black backing plate and I was just going to remove the center pin so I wouldn't have to alter the grille.
Old Jun 14, 2013 | 12:14 PM
Dangerbird's Avatar
The grille design for the 442 is so much tougher looking!
ezman604
Aug 17, 2015 06:51 PM
ezman604
Aug 14, 2015 05:32 AM
'66 88
Nov 2, 2013 03:28 PM
Dangerbird
Jun 14, 2013 12:22 PM
