1970 cutlass w-31
Old Dec 24, 2010 | 05:14 PM
rlarson831's Avatar
1970 cutlass w-31
I have 1970 w-31 all matching numbers,, when restoring the car i had the torque converter rebuilt now when you put it in gear it wants to take off,
it has no stall hardly at all so i called the trans shop they didnt know what stall a w-31 should have and i cant find it in any of my books does anyone know what the factory stall should be???http://members.***.net/rlarson831/oldssite.shtml
Old Dec 24, 2010 | 06:26 PM
jensenracing77's Avatar
welcome. i am sure someone will have an answer for you soon. looks like a great car!
Old Dec 24, 2010 | 08:09 PM
z11375ss's Avatar
Senior Moment Member
You have to figure it is in the 2300 to 2500 area. I can't believe no one has the exact number here. Where the hell is Norm when you need him?
Old Dec 25, 2010 | 07:49 AM
snowballs442's Avatar
Resident Eskie
I was thinking that mine was 2500 stall.
Old Dec 25, 2010 | 07:55 AM
citcapp's Avatar
I believe the 455 came with a 2000 stall
Old Dec 25, 2010 | 08:04 AM
Resident Eskie
Its a 350...with a 2500 stall.
Old Dec 26, 2010 | 06:13 PM
rlarson831's Avatar
Thanks for everyones input that really helped im going with the 2500 stall.
Old Dec 26, 2010 | 06:20 PM
BlackHillsW31's Avatar
This link talks about the stall rpm's:
https://classicoldsmobile.com/forums...converter.html
Old Dec 27, 2010 | 09:02 AM
InfoJunkie's Avatar
InfoJunkie
Originally Posted by rlarson831
... i had the torque converter rebuilt ..... i called the trans shop .....
Just a word of advice which has been said on here before, mark your parts before they go away so you'll know your getting the same thing back. Some shops will use your parts as cores and buy remans from larger companies to give you back. A friend of mine had that problem with a TF727 a few years back.
Old Jan 2, 2011 | 10:47 AM
Elephant_Engine_Ernie's Avatar
You should add that beautiful '70 W-31 to the registry!
http://www.wmachineregistry.com
37 1970 W-31s registered.
jstrits
Aug 8, 2014 07:47 PM
Nickyloves442s
Oct 24, 2012 04:55 PM
charlierogers
Oct 14, 2011 09:44 AM
