1970 Cutlass 12-bolt rear end
And to clarify further, it is not a "12 bolt" axle. The number of bolts refer to the bolts holding the ring gear to the carrier. It is coincidental that on Chevy axles the number of bolts on the rear cover matches the number of bolts on the ring gear. That is not normally the case for most rear axles. The Type O axle uses ten bolts to hold an 8.5" ring gear to the carrier. The Chevy 12 bolt uses 12 bolts to hold an 8.875" ring gear to the carrier. Completely different axles. Nothing interchanges.
monzaz
October 26th, 2020 07:05 PM
rcdynamic88
Drivetrain/Differentials
April 7th, 2015 11:21 AM
350TurBRO
September 12th, 2014 11:52 AM
monzaz
September 11th, 2012 08:27 PM
Aceshigh
June 10th, 2010 08:16 PM
