1970 Cutlass 12-bolt rear end
Old Aug 11, 2013 | 12:10 AM
HitTheHole's Avatar
I have a 1970 Cutlass Supreme Convertible with a 12-bolt rear end. Was that rear end standard or an upgraded option?
Old Aug 11, 2013 | 12:31 AM
svnt442's Avatar
It's an O-Axle. 12 bolt cover with a 10 bolt ring and bolt in axles. Standard on all Oldsmobile cars from 67-70 except Canadian built cars.
Old Aug 11, 2013 | 12:33 AM
HitTheHole's Avatar
Thank you very much for the clarification!
Old Aug 11, 2013 | 05:27 AM
drop top olds's Avatar
Yes, last year of the O axle. In 1971 went with corporate rear end with bolt in axles (I think).
Old Aug 11, 2013 | 09:17 AM
And to clarify further, it is not a "12 bolt" axle. The number of bolts refer to the bolts holding the ring gear to the carrier. It is coincidental that on Chevy axles the number of bolts on the rear cover matches the number of bolts on the ring gear. That is not normally the case for most rear axles. The Type O axle uses ten bolts to hold an 8.5" ring gear to the carrier. The Chevy 12 bolt uses 12 bolts to hold an 8.875" ring gear to the carrier. Completely different axles. Nothing interchanges.
monzaz
Oct 26, 2020 07:05 PM
rcdynamic88
Drivetrain/Differentials
Apr 7, 2015 11:21 AM
350TurBRO
Sep 12, 2014 11:52 AM
monzaz
Sep 11, 2012 08:27 PM
Aceshigh
Jun 10, 2010 08:16 PM
