1970 Console shifter
Old Apr 8, 2014 | 03:20 PM
Chuxter's Avatar
1970 Cutlass Supreme
I just recently viewed a thread that said the console shifters in the 70-72 are different. Is this true? And is there anywhere to get parts to rebuild shifters?
Old Apr 8, 2014 | 03:28 PM
oldsmobiledave's Avatar
define different
Different from what?
Old Apr 8, 2014 | 03:51 PM
jensenracing77's Avatar
71-72 are the same. 70 will work in a 71-72 but it has the neutral safety switch on it and the harnesses are diferant for 70. after installed they all look the same.
What parts do you need?
Old Apr 8, 2014 | 04:12 PM
Olds442redberet's Avatar
I was wondering why my 72 Cutlass was missing the neutral safety switch. Thanks
Old Apr 8, 2014 | 04:26 PM
RetroRanger's Avatar
72 Olds CS
the 67-70 auto floor shifter uses the NSS on the shifter the 71-72 uses the NSS on the column, the 70-72 uses the same console.
the shifter mounting base is different but similar, the actual chrome shift arm 70-72 is the same
Old Apr 8, 2014 | 05:27 PM
I love this forum! Seriously! I am learning so much from threads like this one. Yesterday I learned their was a differences between the sport mirrors from 1970 and 1971, and today I learned about the differences between the consoles. Thanks guys
Old Apr 9, 2014 | 09:25 AM
Chuxter's Avatar
Im missing the cross bar and ****.not exactly sure if anything else as I wasn't the one that took it apart
Old Apr 9, 2014 | 09:37 AM
Octania's Avatar
photos would help...
Old Apr 9, 2014 | 11:14 AM
Chuxter's Avatar
Going to try and take some tonight
Old Apr 9, 2014 | 11:54 AM
72 Olds CS
the walnut **** is the same 70-72 and is availible repro or from any of the good parts sellers here on CO the cross peice that you pull up on to move the lever would have ot come form a donor unit
Old Apr 9, 2014 | 02:46 PM
I haved two floor shifters, complete, both are 1971-72 models. I'll let one em go for $100.00 each, plus shipping. Your base and the 1971-72 handle from one of these and your set.
marxjunk
Jun 12, 2014 12:34 PM
fast67vellen2o
Jul 8, 2012 10:01 AM
oldsw31
Apr 17, 2012 05:34 PM
pcard
Apr 4, 2012 07:36 AM
302Camaro650HP
Nov 24, 2009 02:26 PM
