1968 Cowl Tag Location
Hey Guys,
Need help with location of cowl tag on my 68 Cutlass S vert. I had the entire cowl replaced and was sure I had some pictures of the exact location of the tag but I can't find them. Of course I know generally where it goes but I want to position it correctly. Would love to see some 68 cutty cowl tag pictures so I can get this thing placed correctly. Thanks in advance!!
Hi John
I looked at three 1968's and they're slightly different from each other, so I'm not sure there's a "set" location yours could go on. I'll attach some photos but they vary from 1 inch to 1 1/2 inches from the edge of the firewall. The drivers side is close to the seam in the pinchweld, but may not be exactly there. One tag is from a Lansing car, the other two are from the Fremont plant. Did the rivet holes in your new firewall get welded shut? If you can identify them that would be the easiest way to secure it. John
I took a few other pictures, if you'd like you can view them at: http://s90.photobucket.com/user/2blu...?sort=3&page=1
1968Cutlassfallbrook
January 6th, 2010 03:33 AM
