1966 Cutlass 4 speed question
Old Jan 17, 2007 | 10:12 AM
Mr. King's Avatar
Does anyone have a book or website that would tell me how many 1966 Cutlass 4 speeds were made? I have almost never seen one, except as a 442. I'm just wondering if I have a rare car.
Thanks in advance.
Steve
Old Jan 17, 2007 | 11:13 AM
Oldsguy's Avatar
Past Administrator
I don't think I could help you specifically, my reference for production numbers has a chapter at the end of each year which says what percentage of each model was ordered with a particular option. Therefore we might be able to extrapolate a guess as to how rare your car might be but that would be about the extent of it. I don't think there were specific numbers kept on which vin recieved which option, except the build sheet of course. But I mean no records that are in a central database. I read someplace else that Oldsmobile did not have good documentation compared to say, MOPAR where supposedly every option is indicated in every vin and documentation was extensive. Anywho, I will try to remember to bring my reference book to work and update you on this. My home computer got a virus or something and it is real sick right now. Good luck though. I'll try to remember.
Old Jan 18, 2007 | 04:42 AM
Oldsguy's Avatar
Past Administrator
Ok, here goes. The 442 was an option package as well that year, not a seperate model in it's own right (you probably already know that), the car had a standard 3 speed on the column, with an automatic as an option ( proabably knew that too), there was a 3 speed manual floor shift option, a Hurst 4 speed manual transmission with floor shift for $184, OR a close-ratio 4 speed manual transmission with floor shift for $184. So you could have either of the last two options, I don't know the codes or how to determine which your car has. There are no percentages for any of these options listed for that year/model, sorry. By the way, the base model was the f-85 and the cutlass was also a sub-group including standard, deluxe, cutlass and 442. That is about all that is listed.
Old Jan 18, 2007 | 05:06 AM
Mr. King's Avatar
Dan, Thanks for the info!
My car is a 1966 F-85 Cutlass Holiday Coupe. 330ci motor, a M21 (wide ratio) Muncie 4 speed with the Hurst shifter and 10 bolt rear with factory 390 gears. It also has the factory console with the "performance" vacuum gauge.
It is a very fun car.
Big Mikey
Mar 27, 2013 06:51 AM
CutlassLegend
Jul 30, 2011 07:44 PM
Mr. King
Dec 12, 2007 05:47 AM
Mr. King
Jun 5, 2007 06:38 PM
Mr. King
Feb 12, 2007 08:51 AM
