1964 Cutlass keys
Old Aug 11, 2022 | 06:40 AM
mattking's Avatar
1964 Cutlass keys
Should the door locks, trunk, and the glove box locks be keyed the same on a a 64 Cutlass?
Old Aug 11, 2022 | 07:25 AM
Yes. IIRC, on my '64 one key operated everything.
Old Aug 11, 2022 | 07:50 AM
Actually, no. The trunk and glovebox are separate from the door and ignition. The interesting thing about the 1935-1966 key blanks, however, is that both the octagonal (B10) and round (B11) blanks use the same blade. Only the shape of the head is different to differentiate between trunk and ignition keys. You can slide the ignition key into the trunk lock and vice-versa, which is not the case on the 1967-up cars where GM changed the lock configurations. You can also cut an octagonal blank to fit the trunk or a round blank to fit the ignition. It is also possible to rekey all the locks on the car to use one key if you want. My 1962 F85 wagon uses one key (tailgate is the same as the door/ignition), but sedans used a separate trunk key. This was so you could give the valet only the ignition key and not provide access to anything in your trunk. On a wagon, that really didn't matter.
Old Aug 11, 2022 | 08:28 AM
mattking's Avatar
Thanks guys....
I bought a set of locks for everything (they are the octagonal and round keys you described), and they gave me matching trunk and doors, with a separate glove box lock, and a separate ignition key, I did try them out and they do use the same keyway, I think Ill see if ye old local locksmith will rekey the glovebox to fit the door key.
Old Aug 11, 2022 | 09:18 AM
Joe, I have a very clear memory of a '64 Cutlass 2-door hardtop that I purchased from the original owner in 1984 and being able to open the trunk with the ignition key. In fact, there was no secondary key -- only an identical spare. It stuck in my memory because up to that point every GM car I'd driven used separate keys. Is this some kind of weird anomaly?
Old Aug 12, 2022 | 07:42 AM
edzolz's Avatar
Never owned a 64 but have owned two 65's and the ignition key could be removed with the ignition in run position. I always wondered why GM would do that.
Old Aug 12, 2022 | 09:33 AM
Dunno, but it sure was handy in a day and age when theft wasn't a very big risk.
Old Sep 6, 2022 | 11:50 AM
rickrock999's Avatar
Crusin in my 6-4
I have a '64 Cutlass. It uses one key for everything. Doors, ignition, trunk, and glove compartment. I don't know if someone switched it that way as I have only had the car for a year and a half. My key can also be removed while car is running.
Old Sep 6, 2022 | 01:55 PM
oldstata's Avatar
Justin
i was also told 64 used the same key. I did recently have joe cut a key per a door lock code on a 64 cutlass convertible. It opened all locks. doors trunk, ignition and glove box door all original locks
my 65 that has all original locks use two key codes for doors and ignition and truck and glove box
Old Sep 6, 2022 | 05:06 PM
harleyrules's Avatar
One key works on my 64 Cutlass. I have owned 4 64 Cutlasses and all used 1 key..
jmos4
Jul 11, 2022 08:30 AM
shiftbyear
Jun 4, 2022 07:09 PM
Jonesmen
Sep 28, 2021 05:12 AM
classicmuscle442
Jan 8, 2017 07:56 PM
kbeler
Feb 8, 2015 06:00 PM
