What could be causing noise in steering column
Old April 13th, 2014, 10:38 AM
RandyS's Avatar
I have a Tilt Floor Shift Column in my 66. I have been fighting PS issues for a while (separate thread), but noticed this noise when I was working the air out of the steering box installs. I hear and feel sort of a scraping sound as I turn the wheel, but it is not constant, only when the wheel is in a certain position. It repeats at that position no matter which way I turn the wheel. I verified that nothing was touching in the engine bay. There is a new bearing installed at the lower end of the column. The sound seems to come from the firewall area. Any ideas?
RandyS is offline
Old April 14th, 2014, 05:41 PM
RandyS's Avatar
Anyone?
RandyS is offline
Old April 18th, 2014, 08:12 AM
RandyS's Avatar
Still looking for input.............
RandyS is offline
Old April 18th, 2014, 08:44 PM
70 Cutlass SX
pcard's Avatar
Is the sound coming from the top or bottom of the column? I know you said firewall, but which side of the firewall?
pcard is offline
Old April 18th, 2014, 08:58 PM
RandyS's Avatar
The sound appears to come from the cabin side of the firewall, but not at the steering wheel. Here's a strange thing I encountered today. During the install of the new steering box, I took a few minutes to play with the wheel while there was no box installed. The wheel spun freely, with nary a sound. Hooked up the new box and the sound came back. I am stumped.
RandyS is offline
Old April 18th, 2014, 09:06 PM
70 Cutlass SX
pcard's Avatar
Sorry Randy - the only experience I have had with steering noises has been with the upper end, the cancel cam specifically. Can't help you mate.
pcard is offline
Old April 19th, 2014, 09:49 AM
StarGeneral's Avatar
any way you can have a buddy move your steering wheel around while the front end is on jack stands so you can poke your head in the engine bay and locate the sound? Also does the sound occur with the engine running or when it is off?
StarGeneral is offline
Old April 19th, 2014, 10:39 AM
RandyS's Avatar
The noise is coming from inside the car, engine either on or off. Just can't pinpoint it.......
RandyS is offline
Old April 19th, 2014, 11:24 AM
wmlewis's Avatar
Quick question.... May or may not have anything to do with your problem, but is this a column shift?
wmlewis is offline
Old April 19th, 2014, 12:04 PM
RandyS's Avatar
No, floor shift, tilt column. Turn signals work properly.
RandyS is offline
Old April 19th, 2014, 01:50 PM
brown7373's Avatar
I think there are upper and lower bearings on the column. Sounds like one or both is dry or broken, needing replaced.
brown7373 is offline
Old April 19th, 2014, 03:14 PM
I think this will help you.
oldcutlass is offline
Old April 19th, 2014, 03:36 PM
70 Cutlass SX
pcard's Avatar
Wish I had a diagramme like that for my column; the service manual diagramme is not as clear.
pcard is offline
Old April 19th, 2014, 03:39 PM
That diagram is for a later model with ignition in column but its basically the same as far as shaft moving parts.
Old April 19th, 2014, 04:27 PM
RandyS's Avatar
Thanks for the diagram. I'm now wishing maybe I didn't have the tilt column in this car. Looks like a PITA to get to the upper bearing (lower bearing is new). Does anyone know - if there is not enough tension on the bottom bearing (spring between bearing retainer and clamp) if it would cause the upper bearing to make noise? Again, this is not a grinding noise like a bad or dry bearing would make. It is not constant but occurs sort of randomly as the wheel is turned from lock to lock. Happens maybe 2-3 times during the 3 turns, both directions.
RandyS is offline
Old April 19th, 2014, 04:36 PM
rroth01's Avatar
Location: Orion Township Michigan 30 Miles North of the Murder City
Bearing Bushing or Rag Gear ?
If its the Rag Gear I have plenty of them.
rroth01 is offline
Old April 19th, 2014, 04:49 PM
It may be in the tilt mechanism. Have you tried it in a different position?
Old April 19th, 2014, 05:33 PM
RandyS's Avatar
Brand new Rag Joint
Yes, the position of the tilt does not make a difference. Also, was quiet when not connected to steering box.
RandyS is offline
Old April 19th, 2014, 08:26 PM
wmlewis's Avatar
Next guess might be the steering box.. Or steering linkage binding at some point .. Sounds do travel thru the car. A second person underneath may be a good idea like someone suggested earlier...
wmlewis is offline
gthmcty1
May 21st, 2012 06:53 AM
Lady72nRob71
August 9th, 2010 11:34 AM
Bobac455
May 11th, 2010 07:36 AM
yeahbuddy
May 7th, 2010 08:54 AM
silverriff
June 10th, 2008 03:11 PM
Quick Reply: What could be causing noise in steering column
