What could be causing noise in steering column
Old Apr 13, 2014 | 10:38 AM
RandyS's Avatar
I have a Tilt Floor Shift Column in my 66. I have been fighting PS issues for a while (separate thread), but noticed this noise when I was working the air out of the steering box installs. I hear and feel sort of a scraping sound as I turn the wheel, but it is not constant, only when the wheel is in a certain position. It repeats at that position no matter which way I turn the wheel. I verified that nothing was touching in the engine bay. There is a new bearing installed at the lower end of the column. The sound seems to come from the firewall area. Any ideas?
Old Apr 14, 2014 | 05:41 PM
RandyS's Avatar
Anyone?
Old Apr 18, 2014 | 08:12 AM
RandyS's Avatar
Still looking for input.............
Old Apr 18, 2014 | 08:44 PM
pcard's Avatar
70 Cutlass SX
Is the sound coming from the top or bottom of the column? I know you said firewall, but which side of the firewall?
Old Apr 18, 2014 | 08:58 PM
RandyS's Avatar
The sound appears to come from the cabin side of the firewall, but not at the steering wheel. Here's a strange thing I encountered today. During the install of the new steering box, I took a few minutes to play with the wheel while there was no box installed. The wheel spun freely, with nary a sound. Hooked up the new box and the sound came back. I am stumped.
Old Apr 18, 2014 | 09:06 PM
pcard's Avatar
70 Cutlass SX
Sorry Randy - the only experience I have had with steering noises has been with the upper end, the cancel cam specifically. Can't help you mate.
Old Apr 19, 2014 | 09:49 AM
StarGeneral's Avatar
any way you can have a buddy move your steering wheel around while the front end is on jack stands so you can poke your head in the engine bay and locate the sound? Also does the sound occur with the engine running or when it is off?
Old Apr 19, 2014 | 10:39 AM
RandyS's Avatar
The noise is coming from inside the car, engine either on or off. Just can't pinpoint it.......
Old Apr 19, 2014 | 11:24 AM
wmlewis's Avatar
Quick question.... May or may not have anything to do with your problem, but is this a column shift?
Old Apr 19, 2014 | 12:04 PM
RandyS's Avatar
No, floor shift, tilt column. Turn signals work properly.
Old Apr 19, 2014 | 01:50 PM
brown7373's Avatar
I think there are upper and lower bearings on the column. Sounds like one or both is dry or broken, needing replaced.
Old Apr 19, 2014 | 03:14 PM
I think this will help you.
Old Apr 19, 2014 | 03:36 PM
pcard's Avatar
70 Cutlass SX
Wish I had a diagramme like that for my column; the service manual diagramme is not as clear.
Old Apr 19, 2014 | 03:39 PM
That diagram is for a later model with ignition in column but its basically the same as far as shaft moving parts.
Old Apr 19, 2014 | 04:27 PM
RandyS's Avatar
Thanks for the diagram. I'm now wishing maybe I didn't have the tilt column in this car. Looks like a PITA to get to the upper bearing (lower bearing is new). Does anyone know - if there is not enough tension on the bottom bearing (spring between bearing retainer and clamp) if it would cause the upper bearing to make noise? Again, this is not a grinding noise like a bad or dry bearing would make. It is not constant but occurs sort of randomly as the wheel is turned from lock to lock. Happens maybe 2-3 times during the 3 turns, both directions.
Old Apr 19, 2014 | 04:36 PM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
Bearing Bushing or Rag Gear ?
If its the Rag Gear I have plenty of them.
Old Apr 19, 2014 | 04:49 PM
It may be in the tilt mechanism. Have you tried it in a different position?
Old Apr 19, 2014 | 05:33 PM
RandyS's Avatar
Brand new Rag Joint
Yes, the position of the tilt does not make a difference. Also, was quiet when not connected to steering box.
Old Apr 19, 2014 | 08:26 PM
wmlewis's Avatar
Next guess might be the steering box.. Or steering linkage binding at some point .. Sounds do travel thru the car. A second person underneath may be a good idea like someone suggested earlier...
gthmcty1
May 21, 2012 06:53 AM
Lady72nRob71
Aug 9, 2010 11:34 AM
Bobac455
May 11, 2010 07:36 AM
yeahbuddy
May 7, 2010 08:54 AM
silverriff
Jun 10, 2008 03:11 PM
