rear Control arms
rear Control arms
I am about to re-install the rear control arms on my 68 Convertible Cutlass. It looks like the upper and lower have the same control arm for both sides. Does it matter which one goes were.
thanks Bruce
thanks Bruce
Both the tops and the bottoms are the same RH/LH. Sway bar or not is irrelevant. All the rear suspension cares about is the center-to-center length between the bushings. There is no reason to incur the added cost of different RH/LH arms. This topic usually results in a post every six months or so. Welcome to the world of low cost mass production.
one4theroad
September 27th, 2009 10:11 PM
