rear Control arms
Old Sep 22, 2017 | 06:12 PM
servexcell's Avatar
rear Control arms
I am about to re-install the rear control arms on my 68 Convertible Cutlass. It looks like the upper and lower have the same control arm for both sides. Does it matter which one goes were.
thanks Bruce
Old Sep 22, 2017 | 07:01 PM
classicmuscle442's Avatar
Same top ones for either side, but the bottoms could be different if you have sway bar.
Old Sep 23, 2017 | 11:07 AM
Both the tops and the bottoms are the same RH/LH. Sway bar or not is irrelevant. All the rear suspension cares about is the center-to-center length between the bushings. There is no reason to incur the added cost of different RH/LH arms. This topic usually results in a post every six months or so. Welcome to the world of low cost mass production.
Old Sep 23, 2017 | 06:12 PM
If with sway bar are they not boxed? Joe?
Old Sep 23, 2017 | 06:15 PM
My point is that even when boxed, they are still the same on both sides. Your first post implied that the sway bar mounts somehow made them RH/LH. That is not the case.
Old Sep 23, 2017 | 08:11 PM
Got it
Old Sep 27, 2017 | 09:36 PM
servexcell's Avatar
thanks Chris and Joe
i mounted them tonight , next to install springs and shocks.
one4theroad
Sep 27, 2009 10:11 PM
doc
Suspension & Handling
Jul 18, 2009 03:26 PM
Olds luvr
Jan 19, 2009 06:35 AM
z11375ss
Jul 26, 2008 06:04 AM
