Improving Ride on a Daily Driver 1970 Cutlass
Old April 23rd, 2018, 12:30 PM
Darkalley's Avatar
I said it daily driver! I drive my 1970 Cutlass 30 minutes to work about 2-3 days a week in the summer. It is bone stock and it definitely needs new shocks. Steering is very floaty, so of course would like to see that a little tighter. My budget is $1500-4k installed. I'd like to just tighten the ride up a little on the commute, which is 30 minutes each way (mix of highway and side roads). Any suggestions on what I should be doing? Any packages you would recommend off the shelf? I will be bringing it to a mechanic for the work. I am assuming he will have some recommendations but I wanted to do a little research before hand.
Car is a 1970 Cutlass convertible, 350, 4 Speed in great shape.
This seemed like an option. http://m.bmrsuspension.com/?page=products&productid=77
Darkalley is offline
Old April 23rd, 2018, 01:12 PM
I drive mine to work all the time and the suspension / steering is all factory or factory equivalent and it's firm and tight.
  • New springs all around. Spring specs depend upon what ride height, stance, and firmness level you are looking for.
  • New modern gas shock absorbers front and rear.
  • New suspension bushings front and rear.
  • Ensure inner/outer tie rod ends, center link, and idler arm are in good shape. If not, replace with new parts.
  • Ensure ball joints are in good shape. If not, replace with new parts.
Fun71 is online now
Old April 23rd, 2018, 01:48 PM
If your not going to push the car on the road or track. I mean extreme spirited driving, you don't need that kit.
oldcutlass is online now
Old April 23rd, 2018, 02:10 PM
72 Olds CS
RetroRanger's Avatar
A fast ratio steering box like the lares 974 from rockauto, along w fun71s list and a good friend alignment w as much positive caster as possible will make the car feel more like today's cars
RetroRanger is offline
Old April 23rd, 2018, 03:10 PM
^^^THIS! The biggest steering feel difference between older cars and newer ones is from the caster setting. Of course, be sure your front suspension is in good shape first. I would not swap springs unless you think they are sagging. Stiff springs make for an uncomfortable ride and can cause the tires to lose contact with the pavement over bumps - and at that point you have no handling. I like KYB shocks. Also, get the biggest REAR sway bar you can find. The A-body is an understeering pig from the factory. All things being equal, the stiffer end of the car breaks away first. That means you want to make the rear suspension stiffer to make the car more neutral. Herb Adams used to use a 1.5" rear bar on these cars.
joe_padavano is offline
Old April 23rd, 2018, 07:18 PM
dalilama's Avatar
I'll second this. I went through my suspension and did about all of the things on Fun71's list, got it aligned with some good positive caster and it made the car ride much better. But the biggest noticeable improvement was adding a 1" sway bar in the back. Corners much better and flatter. Well worth the additional $$!
dalilama is offline
Old April 24th, 2018, 04:08 AM
Darkalley's Avatar
thanks exactly the type of expert advice I was looking for!
Old April 24th, 2018, 11:12 AM
My442's Avatar
My .02:
Shocks - Bilstein
Suspension Parts - MOOG
Springs - Eaton
Use rubber on the control arms, and poly on the front sway bar links and bushings
Radial tires with a pressure of 30 PSI
Be sure that your front wheel bearings are good as well.
My442 is offline
Old April 15th, 2019, 11:06 AM
Darkalley's Avatar
Hey guys I checked with Rockauto and the lares 974 is out of stock. Can you recommend another supplier?
Old April 15th, 2019, 11:13 AM
dalilama's Avatar
I installed this one - very happy with the fabrication and fit:
https://www.opgi.com/cutlass/1972/ch...nents/ADDC939/
dalilama is offline
Old April 15th, 2019, 11:23 AM
Darkalley's Avatar
that doesn't show as a steering box!
Old April 15th, 2019, 11:25 AM
72 Olds CS
Call lares they're a us company, I've spoken to them on the phone a couple times over the years.
there is other options too a jeep box ( search on here common swap), have yours rebuilt w fast ratio, big bucks replacement fast ratios are availible too.
Old April 15th, 2019, 11:29 AM
72 Olds CS
I just looked on RA they list it as a return and rebuild service. I have my orifginal box if your interested I would send it to them they would send you the rebuilt one PM if interested
Old April 15th, 2019, 11:35 AM
dalilama's Avatar
Sorry - was thinking sway bar...nevermind!
dalilama is offline
Old April 15th, 2019, 11:43 AM
delete
droptopron's Avatar
There is a guy on the Oldsmobile 442 W30 & Hurst Olds Fan Club of Facebook page out of CA that rebuilds stock units for quicker ratio. I haven't used him but people speak highly of him. One thing is you'll want to locate a core so you have the new box in hand when they take the car apart.
Wheels & tires can make a big difference depending what you are running now. A good radial tire on your stock 14" wheel helps a lot if you want to keep it original looking.
I went with a set of 17's with General tires and it made some difference. If you are a smart shopper you can be all-in for about $1K-$1250
droptopron is offline
Old April 15th, 2019, 11:59 AM
Will22's Avatar
These guys do good work if you want to have your steering box rebuilt.
https://www.powersteering.com/
Will22 is offline
george landis
September 6th, 2017 08:05 AM
brian060901
February 16th, 2015 07:34 PM
navvet
Suspension & Handling
15
July 7th, 2014 04:09 PM
lvelocci
21
December 31st, 2011 05:41 AM
BerBer5985
July 9th, 2009 04:58 PM
Quick Reply: Improving Ride on a Daily Driver 1970 Cutlass
