Ididit column in '68 Cutlass same as '68 Chevelle?
Old August 14th, 2013, 05:12 PM
c-towndave's Avatar
Does any one know if the floor shift tilt column from Ididit for a '68 Chevelle the same as the '68 Cutlass. I am looking at column part no. 1120680010 (paintable steel). One vendor on ebay says it will fit. Other vendors do not specify.
I will call Ididit, but was wondering if anyone had any experience with this before I called.
Dave
c-towndave is offline
Old October 20th, 2013, 04:29 PM
JPMDaddy's Avatar
had a question about 66 vs 67 IDIDIT column and called them direct - very helpful
http://www.ididitinc.com/
JPMDaddy is offline
Old October 21st, 2013, 07:41 AM
Dave
The columns should be the same. Be careful as to what the diameter of the upper part of the column is. All the Ididit columns I've seen use the larger 1969-up diameter.
joe_padavano is offline
66 Olznut
July 26th, 2014 06:59 AM
317Cutty
June 18th, 2014 10:53 AM
ros6872
February 24th, 2010 05:50 PM
jeffreyalman
June 6th, 2009 06:28 PM
doc
January 15th, 2009 03:11 PM
Quick Reply: Ididit column in '68 Cutlass same as '68 Chevelle?
