Best Solvent?
Old Mar 13, 2020 | 06:54 PM
James W. Frey's Avatar
Best Solvent?
Hi All,
I just bought a Parts Cleaner tank from Harbour Freight, it states to use 12 gallons of a water-based solvent. I'm curious to know if any of you have any recommendations? I don't have much experience with water-based solvents, are they good at removing tough grease and also where could I buy 12 gallons of it!?
Many thanks for your advice!
james
Old Mar 13, 2020 | 07:13 PM
Years ago the water based cleaners didn't work very well, so I used general purpose Naphtha. It cleans well, used to be relatively cheap, lasts a long time, and doesn't evaporate fast.
Old Mar 13, 2020 | 07:19 PM
jaunty75's Avatar
I bought a small parts washer from Amazon, and I bought this stuff to use as the solvent. It worked very well. I used it to clean all the brackets for a power steering pump. I was replacing the pump, and I figured I might as well clean the brackets since I had them out of the car and they were quite gunked up.
The instructions on this say dilute 10:1 with water, so 1 gallon of this should give you 10 gallons of solvent. With 2 gallons of this, you'd have plenty.
https://www.amazon.com/gp/product/B000EALHHG/ref=ppx_yo_dt_b_asin_title_o06_s01?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000EALHHG/ref=ppx_yo_dt_b_asin_title_o06_s01?ie=UTF8&psc=1
Old Mar 13, 2020 | 07:42 PM
Charlie Jones's Avatar
Phantom Phixer
I use mineral spirits in mine .
I went to Lowes and got a couple of 5 gallon cans .
Be careful to use gloves in this stuff , as it will dry your skin out .
Especially when it's " new " and hasn't been diluted with oil and grease .
Old Mar 13, 2020 | 09:35 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Safety clean services mine. The water-based stuff doesn't work in my experience.
Old Mar 15, 2020 | 05:44 AM
ELY442's Avatar
X2, also I use Gunk M720 brake cleaner chlorinated 19 oz can for hard to reach small parts cleaning.
Old Mar 16, 2020 | 10:54 AM
oddball's Avatar
I used the purple degreaser stuff from Home Depot, maybe 2:1 diluted, for a long time. But the water based stuff that works well will eventually eat the paint then rust through the tub.
You can use mineral spirits, which is the most effective and cheapest way, but the evaporation rate is pretty high.
I currently use parts washer solvent from Tractor Supply. It's basically mineral spirits modified for a higher flash point (a bit safer) and slightly slower evaporation. I still drain back into the cans after every use.
There's a bunch of info out there on upgrades for these things. I have a Fram filter, a little giant pump, drain valve, and gaskets on the lid.
rocketraider
Feb 6, 2021 03:52 PM
Michael_
Aug 4, 2017 01:10 PM
Railguy
Feb 28, 2016 11:15 AM
jpc647
Nov 20, 2012 11:37 AM
Mark71
Apr 28, 2011 05:38 AM
