Windows 10 and downloading pictures from my camera
Old Jun 3, 2018 | 08:55 PM
Tedd Thompson's Avatar
I'm having problems getting the pictures out of SD card into my computer. I've never had any problems getting this transfer to happen with a couple of my older cameras but all of a sudden this new to me Canon glph1901s isn't getting along with Windows 10. I get no promps when I insert the SD card and I.m not sure where to go from here. By the way there was a major update on windows 10 the other day I have idea if that could be a problem or not.What could I have done or what do I do to resolve this problem. I probably have a hundred or more pictures stacking up on that SD card I would like to down load before it gets to burdensome to handle..... Help...... Tedd
Old Jun 3, 2018 | 09:07 PM
OLDSter Ralph's Avatar
Can you right click on the Microsoft (start/shutdown) icon ? Then click on "Windows Explorer" ? Perhaps you can "explore" to find the SD card. It sounds like the computer is not recognizing the SD card. It should show up as a "drive". I don't have Windows 10 and won't allow it to be installed on my computer. Good luck !
Old Jun 3, 2018 | 10:21 PM
svnt442's Avatar
Look for the file folder on the taskbar, that is where you will be able to see the camera as a drive. Then you can move the pictures to a folder on the computer.
Old Jun 4, 2018 | 04:55 AM
jharsh's Avatar
Tedd,
I know this may sound basic, but you do have the camera turned on.
Old Jun 4, 2018 | 05:31 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I think he took the card out of the camera and inserted it into his computer. That is how I do mine. I have a Canon and Windows 10 and I have had no issues. I always get the prompt when I insert the card. I think the card shows up as the I drive on my computer.
Old Jun 4, 2018 | 07:47 AM
The SD card will show up "IF" the software "recognizes it". It sounds like the computer does not know he has inserted the card. I am sure someone that's a computer whiz will know what needs tweaking to make things happen.
Old Jun 4, 2018 | 12:02 PM
nj67's Avatar
Most likely a driver issue. Just get a card reader it will read the images no problem the issue you are having is the communication between camera and cpu.
Amazon Amazon
Old Jun 4, 2018 | 04:14 PM
Old Jun 4, 2018 | 04:28 PM
CRUZN 66's Avatar
Olds Fever
I usually use a USB cable directly from the camera to the computer... If you are having a problem using the SD card only, try putting it back into the camera and use the camera itself as the drive unit... It may simply be an SD card reader problem...
jaunty75
May 1, 2017 12:03 PM
jaunty75
Jan 30, 2017 02:44 PM
jaunty75
Oct 13, 2016 05:53 AM
truckman5000
May 30, 2016 08:37 AM
Tedd Thompson
Jan 7, 2016 03:36 AM
