Old Skool Engines
Old Oct 18, 2018 | 09:18 AM
cublex's Avatar
Old Skool Engines
Is it me or do these older car engine put off a lot more heat than the new ones. It makes me concern they are running hot..any input is appreciated
Old Oct 18, 2018 | 09:22 AM
Based on what, old cars generally run a cooler thermostat than the newer counterparts.
Old Oct 18, 2018 | 10:24 AM
cublex's Avatar
I was just referring to the heat that was coming from the engine overall...the car isn't running hot or anything it just feels a like a lot of heat coming from the engine compartment
Old Oct 18, 2018 | 02:20 PM
Do you have a temp gauge hooked up? All engines when warmed up are hot to the touch.
Old Oct 18, 2018 | 02:34 PM
CRUZN 66's Avatar
Olds Fever
From a metallurgical standpoint, the heat difference from an older engine constructed of iron/steel will naturally hold more heat for a longer period of time then current engines which are mostly constructed of aluminum components which dissipate heat at a much faster rate... As stated, from a temperature issue, the thermostat controls the degree of heat whether aluminum or steel...
Old Oct 18, 2018 | 02:40 PM
cublex's Avatar
Thx make sense
Old Oct 22, 2018 | 09:32 PM
Greaser007's Avatar
I agree with Cruzn. The 455 is like a living room heater, where as the little aluminum engines are like a hand-warmer
Old Oct 23, 2018 | 06:26 PM
Also, new engines are less cylinders, smaller displacement, and thinner, as well as aluminum, so the thermal mass is not there. A popular Toyota V6 only weighs some 350 lbs.
Old Oct 24, 2018 | 07:49 PM
SWinner's Avatar
Check your firewall and floor insulation. My T-Bird has the exhaust running very close to the floor. In the summer it was too hot to drive. There is a product called Lizard Skin. (https://www.summitracing.com/parts/liz-13032/overview/) I sprayed it from the top of the firewall to the back of the floorboard. It makes a big difference in the heat that used to come through the metal.
Good luck,
Old Oct 25, 2018 | 09:54 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Bigger Engine Bigger Heat! Compare a 400/455 intake to most anything today. Its either smaller or plastic. You can have a football game on an Olds intake!
Old Oct 25, 2018 | 02:41 PM
VC455's Avatar
Barely Registered
...do these older car engine put off a lot more heat than the new ones...
In a word, yes.
Look at it this way: the fuel economy is a lot worse with older car engines versus newer ones. That means they burn more fuel; burning fuel gives off heat; therefore, older engines give off more heat.
As you realize, the cooling systems of the older cars were made to deal with this extra heat.
Kyle's 77 Cutlass
Dec 24, 2013 01:17 PM
don71
Sep 2, 2013 04:55 PM
cutlassgal
Apr 9, 2010 09:09 PM
71W31
Oct 8, 2009 07:00 AM
rocketraider
Sep 24, 2009 08:30 AM
