Garage infestation- not mice, ANTS?
Not the big beasty carpenter black ants
I was wondering why bits of foam insulation board were appearing by the millions in the corner. Cat? no... Mice? no... the other day i was looking for pulleys, and WAY up in the far corner, just under the attic space.... a few teeeensy ants. like 3-4mm long.
Why would they want to live in my garage attic. No food up there. Some useless old factory service manuals. No water. WTH?
What can be done to convince them to leave?
Boric acid and / or diatomaceous earth around the outdoor areas? Spray of Death inside?
Several species of ants chew up rigid foam insulation and cellulose... not for food, but to create nests. What you found are probably new hatchlings from a nearby nest made in the foam insulation. Since there is no food for them near the nest, they need to travel somewhere else (outside?) to get food. I use a product called Suspend SC as a perimeter spray (inside and out) around my garages. It leaves an invisible, odorless residue that kills bugs when they cross it, and it lasts at least a couple of months. It's reasonably safe stuff for humans and larger animals, but very toxic to insects, and much more effective than bug bombs, boric acid or dynamite.
I started using it to reduce the spider population in the garage (nothing else had worked for me), and I no longer have spiders or any other bugs inside.
Shoot em or bring in some bigger ants to chase them away, They bigger ones are easier to shoot. Maybe they are looking for a winter home. Seriously I would watch them (they seem to always travel in a path). Spray them in the nest and the trails they follow.
I had a problem in the house I bought a few months back when we moved in. We used a two pronged approach, bait traps (little tins with windows) inside and a general purpose killing spray outside on the actual nests or locations where we could see them congregating. It took about a week to eradicate them. The traps are still in the corners on the floor, they aren't too visible and are insurance against future attacks.
I'm glad I run across this string. We have ants that I just can't seem to get rid of. I've tried about everything at Lowes and am about to resort to a professional. You won't see the first sign of them for a few weeks, then the next thing I know there is a trail of dog food walking across the kitchen floor. I'm going to try the Suspend and see what happens.
Doyourownpestcontrol and domyownpestcontrol dot com are both great sites for buying this pro grade stuff for home use. They even sell termidor if you have a termite issue and rat control stuff (sans guns...).
Knowledgable folks at both places, too.
I have been using these pro products for years with great success. Just read the label and apply common sense while applying and it is all safe.
Forget the local big box store sprays - bugs drink it up during happy hour and love it.
I agree about the stuff sold at the big box stores... big retail bucks for ineffective, watered-down products. You might as well light dollar bills on fire and throw them at the bugs.
I had recently tried an mosquito kill experiment using Bifen IT a couple days ago after my quarterly general spraying around the foundation, windows, garage etc.
I used the pump sprayer and sprayed most of the back yard grass, bushes, low trees, patio, etc. I mostly sprayed undersides of leaves, furniture, patio cover, etc where the pests rest for the day. For the whole day I used 10 gallons of spray (10oz of Bifien).
Now, instead of my legs being swarmed by 25 mosquitoes within a minute, I might see 1 or two or none. It is even safe to stand in the grass now! Not sure how long the results will last, but it works great now. Even my neighbors notice a reduction of them.
It is all approved for use this way per the label, just do not use on plants with edible fruits or veggies.
While this is a bit off topic from the OP, I just wanted to let you all know what these good chemicals can be used for. And for the price, WELL worth it and will last a long time.
Makes working on the car more enjoyable, too!
Quite the track of beasties in the garage today
I never got around to poisoning them.
ready to try Terro / Borax with sugar water now
I have 20 mule team Borax on hand for brazing needs...
Cutting the trees and weeds away from the outside of the garage to see if/where they are going in/out is no fun.
damn critters is soiling my one remaining '68 ribless shroud 398248.
20 mule team borax and sugar water was very effective
Small dish with ramps to get at it
very few left a couple days later
went and spent $7 on the same chemical in plastic dishes at the store, put one inside, one outside.
Had I known 'twas that easy I would have done 'em in last year.
jack69cutlass
Oct 23, 2012 09:56 AM
Del70
May 18, 2011 04:10 AM
