Fouronado HMN article
Old Nov 17, 2014 | 09:48 AM
Octania's Avatar
http://www.hemmings.com/r/ct/MTcyNzc...851&refer=news
has photos as well
"In the fall and winter of 1967, Hurst Performance Research took a brand-new 4-4-2 and installed an entire W34 Toronado driveline–front-wheel-drive, torsion bars, the lot. The Toronado’s frame was joined with the 4-4-2′s frame about halfway down the wheelbase. The floor was flattened to eliminate the driveshaft hump, a beam axle on stock 4-4-2 coil-spring-and-trailing-arm suspension resided at the rear, and it wore polished Toronado wheels; it has been freshly restored within the last year by its current owner, Fred Mandrick of Scottsdale, Arizona. We wondered: Was the driving experience really worth all of the re-engineering? Or does it just feel like another A-body?
In order to get proper context for a car known popularly as the Fouranado, we drove two other ’68 Oldsmobiles from Mandrick’s collection: an unrestored 19,000-mile 400-powered 4-4-2 coupe and a fully restored Hurst/Olds. Both were automatics, and both were shod with era-correct bias-ply tires in the factory size. The Hurst/Olds managed to feel both quicker and more relaxed; those extra 55 cubes meant power and torque on reserve. Not that the stock 400-cube 4-4-2 was frenzied, by any means: It was plenty quick as it sat, but you could sense that the 400 had to work harder to do what came easily to the Hurst/Olds. The H/O just deepened its voice an octave and hurtled forth like a freight train, and it shifted harder, too.
The Hurst/Olds leaned and understeered more in the turns, but the quicker power steering made it far simpler to correct your line than in the standard 4-4-2, whose Armstrong steering wanted nothing more than to self-correct to the straight-ahead with a great deal of force. And so, to the Fouranado. Inside is stock Olds A-body everywhere, from the gauges to the seats to the carpet. The flat floor (actually the stock A-body floor with the driveline tunnel sectioned out) is sadly hidden by a console. Turn the key on the dash. The Fouranado sounds a little higher-strung at idle than a production Hurst/Olds does–then again, this is a 400-hp Toronado mill. Accelerate, and the nose doesn’t seem to want to come up. This is a good thing: With the drive wheels in front, the last thing you need is the nose rising skyward at launch to unweight the tires and go up in smoke.
Oh, it’s plenty fast–power-wise, it’s as much a step up from the Hurst/Olds as the H/O is from a standard 4-4-2. But the street cars’ squat on their rear tires allows air to get under the nose, keeping it up in a sort of cowboy rake as you accelerate. The Fouranado resists. (Doubtless the extra weight of the driveline, reproportioning the weight forward compared to a standard A-body, plays a role too). Without the nose rising, there’s less air to get under the front of the car and keep it up as you accelerate; as a result, you feel more hunkered down and planted. But it’s more than that. In a world of transverse-engined, front-drive cars, the power limit has long been understood to be around 300 hp without making a car uncontrollable.
But GM has managed to put 500 foot-pounds of torque through that hard-shifting OM-case transaxle with nary a peep out of the front tires. There’s no torque steer at all. The sensation of driving a front-wheel-drive car isn’t just minimized, it’s eliminated. If anything, the hybrid chassis is overwhelmingly calmer than the stock A-bodies’, making for a more sure-footed ride. With the stock 4-4-2 and the Hurst/Olds, virtually every road irregularity worked its way into the suspension to be heard and felt; you think it’s Oldsmobile smooth until you try the Fouranado, which has a distinctly magic-carpet vibe about the ride. The Toronado’s torsion-bar suspension doesn’t seem to work as hard to absorb road irregularities as a standard unequal-length A-arm suspension does–yet the result is smoother and less intrusive. (Or if it is working that hard, it disguises its actions better.)
Whoop-de-doos are taken with confidence; the chassis urges you to take things further. Steering is quicker, if devoid of road feel, and bias-belted tires that squealed at 25 MPH in regular A-bodies didn’t start yelping for another 20 MPH on the Fouranado. How can this be? Track width can’t be the only answer here, although the Toronado’s driveline has more than two inches on a stock 4-4-2 of the era. The 7.75-15 Goodyear Blue Streaks also help; standard 4-4-2s came with F70-14s and the Hurst/Olds with G70-14s. A little more meat on the ground rarely hurts ride or cornering. Also, consider: The Toronado’s driveline was built for a car that weighed fully half a ton more than the A-body it now resides in. Using less-stressed stock components should make it lean less in turns and accelerate harder out of them.
The Fouranado certainly feels more contemporary, more sure-footed, and more driveable, than a lot of cars that were its contemporaries. Such a beast may resist hooning about–no big stinky burnouts, no hanging-out-the-tail antics–but it makes you want to take long trips without thinking twice. As a road car, this machine is compulsively driveable. GM adopting a set-up like this for its A-bodies could have put it miles and years ahead of the competition; it certainly would have helped front-wheel drive get a better reputation than it currently enjoys."
Old Nov 17, 2014 | 09:57 PM
Seff's Avatar
I always wanted to put a 4x4 transmission in that and make it 4WD.
Old Nov 21, 2014 | 09:14 AM
z11375ss's Avatar
Senior Moment Member
Don't forget the MCACN show is the weekend of the 22nd this month. This car was there last year. That's the quality of the cars there. You must attend this show.
Old Nov 21, 2014 | 09:52 AM
Octania's Avatar
link?
Old Nov 21, 2014 | 01:56 PM
ROCKET VAPOR's Avatar
Lance
Originally Posted by Octania
link?
http://www.musclecarandcorvettenationals.com/
Old Nov 6, 2020 | 11:26 AM
Killian_Mörder's Avatar
Octania
Aug 16, 2015 10:22 AM
Octania
Jul 11, 2015 09:19 PM
Octania
Apr 25, 2014 05:46 PM
Octania
Feb 18, 2014 02:18 PM
Octania
Feb 1, 2014 11:54 AM
