Chevy G20 Brake Combo Valve
Old Jul 23, 2019 | 04:27 PM
Hi everyone.
I'm working on my 1990 Chevy G20 van doing brakes. I believe one of the rear cylinders was leaking, which drained the reservoir dry, and the valve in the proportioning valve migrated to shut off the system. After replacing both cylinders I get nada when bleeding. The fronts are fine.
I can find nothing in google or YouTube that specifically talks about the G20 van. It's always Chevy trucks "they're all the same." They are not.
My prop valve has two lines from the Master going into the top, It has various lines going to the wheels and also another block next to it. A couple lines from the other block go out to the wheels.
Which block has the meter? The one block(which is inboard) has plugs on both ends and they come off with a six point wrench/socket. The outboard block has a plug in the front and a line coming out of the back.
My stellar Haynes manual tells me how to remove and replace it, in about one paragraph.
Anyone have one of these vans and have messed with this? Which is actually the prop valve and what is the other block? How will it reset? Thanks everyone.
Old Jul 23, 2019 | 07:16 PM
tru-blue 442's Avatar
Old School Olds
Mike try this forum. It's a good one.
https://www.silveradosierra.com/
Old Jul 24, 2019 | 10:58 AM
Thanks. Had a look around, nothing van. Seems I am a member of this forum but had forgotten. Last log in, 2016. Sheesh.
speck1148
Jan 28, 2018 08:50 AM
deadeyejedi
Aug 18, 2016 08:23 AM
Octania
Jun 7, 2015 11:46 AM
RAMBOW
Dec 13, 2012 04:35 AM
Mark71
May 20, 2011 03:40 PM
