Another score for the budget build...
Old Mar 6, 2016 | 06:35 PM
Bozang1's Avatar
Scored a 12 bolt posi, said to be out of a 68 Cutlass or Chevelle. Guy said he thinks 273 gears. Brand new brakes. $550. Yay!!
Gonna check #'s when I get a chance to verify. But the guy ran a hotrod/speed shop so he was probably right. If not, I'll just flip it..
Old Mar 7, 2016 | 12:02 PM
BackInTheGame's Avatar
If it's actually a Type "O," that is a killer deal! Way to Go!
Old Mar 7, 2016 | 01:34 PM
Bozang1's Avatar
I found numbers and codes along the pumpkin but really don't want to open it up right now or sand down the tubes unless I know exactly where to be. Somewhere along the way someone did a half assed job painting it. If anyone has a pic of where the stamps would be that might help. I believe it is a type "O"
Old Mar 7, 2016 | 02:14 PM
droptopron's Avatar
delete
I can't see the pic great but it looks to have a smooth cover like a Type O would.
Old Mar 7, 2016 | 03:18 PM
Bozang1's Avatar
I took some sandpaper and sanding on the axle tube and found a small "SB" of course in the last area I sanded down. Anyway, if I'm understanding what I read online that means this is a rear with 2.78 gears. (As long as nothing was changed). I will probably open it up before I eventually install it, probably put 3.73 in there anyway.
Old Mar 7, 2016 | 03:54 PM
Bozang1's Avatar
Ok, upon further inspection there are ZERO brakes. They were taken out. The wheel cylinder is all that is left. Everything else is gone! Still a good deal unless I find something bad when opening up. I propped it up and spun the drums and counted. For each full rotation of the drum, the yoke spun 2 and 3/4 times so 2.78 makes sense. I did read somewhere else about 2.73 gears so it's one of those...lol Won't matter much when I put 3.73's in there.
Is there a certain type of paint I should use when re painting this?
Also, will all of my brake hardware just swap right over?
coppercutlass
Apr 26, 2014 03:29 PM
Freddy B
Jun 13, 2012 11:36 AM
deejai35
Mar 10, 2012 08:56 PM
CMP
Oct 6, 2011 07:56 PM
Vega
Jul 22, 2011 11:38 PM
