86 Chevy c10
Old Nov 30, 2021 | 10:38 AM
72cutlassdog's Avatar
86 Chevy c10
I have a 86 chevy c10 with factory 4.3 v6 motor. I found a 350 out of a 75 chevy truck. The question I have, will this be a direct fit? I know the motor mounts and fan shroud have to be changed.
Old Nov 30, 2021 | 04:05 PM
edzolz's Avatar
Personally, I think you are on the wrong site for this question.
Old Nov 30, 2021 | 09:35 PM
I would agree. Now if he wanted to swap in a 455 this would be the place to ask for info!!
I have done this swap several times. You need to change the frame mounts to a V8 style. While the 4.3 v6 and v8 engines share lots of parts, the engine mount location is in a different place. I think the power steering and other accessory brackets will fit.
This is about the easiest swap there is, simply because GM made millions of these trucks. Parts are easy to find.
Old Dec 1, 2021 | 01:46 AM
GCH's Avatar
GCH
I have been a member here for many years :
The 1947 - Present Chevrolet & GMC Truck Message Board Network - Powered by 67-72chevytrucks.com
Old Dec 2, 2021 | 08:24 AM
Tedd Thompson's Avatar
I think the placement of this thread is in the correct place/forum. As I understand it and I use it his post is correct here.... Tedd
Old Dec 2, 2021 | 11:50 AM
66_Jetstar's Avatar
The 75 350 would really benefit from a cam and cylinder head swap. Otherwise the performance gain might be a little underwhelming..
glendalegearhead
Jul 5, 2015 11:25 PM
cuttyred
Non-Olds Engines
16
May 27, 2012 06:15 AM
billykissell
Jun 15, 2011 03:08 PM
Chumley
Feb 9, 2009 02:11 PM
77omega
May 30, 2008 11:25 AM
