4 speed overdrive question
Old Nov 26, 2010 | 08:48 PM
z11375ss's Avatar
Senior Moment Member
Am putting in a 700R4 into a Cutty that had an original turbo 350. I was wondering if when you put the trans into 1st, does the lever have enough room to go down into the column and indicator window to actually work? Like disappear into the column indicator. The reason I ask is that when I was a kid I had a Chevelle with a Powerglide. I put a TH350 in it and it had enough room to go down into the first gear that didn't exist before (but really did, it just wasn't marked). Am I being even reasonably clear? I really don't want to put a floor shifter in the car and replace the column. EEsh!
Old Dec 1, 2010 | 12:48 PM
z11375ss's Avatar
Figured out the problem. Put buckets in it with a console. New steering column. Problem solved.
dc2x4drvr
47
Dec 30, 2013 11:28 AM
KEVO35
Bravada
Dec 8, 2012 08:44 AM
Stevec
Feb 13, 2012 03:44 PM
72RocketPower
May 26, 2007 07:23 PM
72RocketPower
Drivetrain/Differentials
Jun 29, 2006 02:37 PM
