Spring collapse
Old Feb 2, 2014 | 06:46 PM
Oldracerjones's Avatar
Spring collapse
I was looking at my new 70 442 and saw the I right rear coil spring has 2 or 3 coils Collapsed on each other at the bottom of the spring. The left does not have any collapsed like that. I'm thinking a break somewhere on the backside. This may also be contributing to my shift linkage being jammed up against the top of the tranny tunnel.
Anything else I should check before changing the springs out?
Old Feb 2, 2014 | 06:57 PM
You might check your rear control arms and bushings.
Old Feb 17, 2014 | 05:24 PM
Fixed It
Well looks like I fixed it. Replaced the rear springs with +1 springs from Eaton, put new rear shocks on and no hitting anymore.
Old Mar 5, 2014 | 05:12 PM
DJS70cutlass's Avatar
Sounds like somewhere along the line the old right spring was installed upside down
and1stp
Nov 4, 2023 07:42 AM
johnnyjaws
Feb 23, 2015 04:30 PM
1956OldsDarrin
Jul 8, 2012 09:37 PM
Longhorncutlass
Mar 2, 2009 01:53 PM
Want-A-Vert
Mar 23, 2007 03:22 PM
