strange pulsing vibration when driving on the highway
Old Aug 17, 2012 | 03:50 PM
cuttysupreme72's Avatar
What could it be? It vibrates every other second in a steady rythm. Drive shaft? Warped crank pulley? Because my crank pulley is warped.
Old Aug 17, 2012 | 03:56 PM
Tire balance.
Old Aug 17, 2012 | 04:06 PM
Thumbs up
Tire balance.
Good call! I forgot all about that. I changed two tires on mine manually because I didn't have the money to take it to the shop to have them changed. SO naturally I couldn't balence them ether. Hey thanks
Old Aug 17, 2012 | 08:31 PM
jaunty75's Avatar
It might not even be a balance issue. They could be out of round, worn unevenly, have a damage belt or tread, or who knows what.
What do you mean when you say you "changed" the tires. You mean you rotated them to different positions on the car? Or did you actually remove the old rubber from the rims and put new ones on? (I'm impressed if you did that!)
Whatever it is, the fact that this problem arose just after you did this is too much of coincidence. The first thing I would try is putting things back they way they were and see if that doesn't eliminate the problem.
Old Aug 17, 2012 | 08:40 PM
bdub217's Avatar
Kickin' It Oldschool
My buddy came to the shop about 2 weeks ago around 11pm and we don't have a tire machine so we just layed the tire on the ground and ran it over with another car and popped it off the rim, getting it to seal back up was a bit tricky but all in all went well.
Old Aug 17, 2012 | 08:47 PM
jaunty75's Avatar
I'm sorry, but the first words to pop into my mind were "oh my god!"
Don't you realize that what you did to get the tires off the rims might very well have been what damaged them? They're not designed to take the weight of a car on their sidewalls.
Forget what I said above about putting things back the way they were if doing so means you're going to run over them again with a car. I think it's a virtual certainty that you damaged one or more tires, and the vibration/pulsing is telling you that they're now dangerous to drive on.
Did you ever see the Red Green Show on PBS? I hope you took a video of how you did this tire job because you should send it in to that show as it would fit in very well. In fact, to make it perfect you would have needed to find a way to work in a little duct tape. Did you use duct tape at all at some point? Maybe to patch a leak? I hope so!
Old Aug 17, 2012 | 11:58 PM
Yeah I changed the rubber manually. Here at home. Its not that hard once you do it a couple times. I had some old alero rims with good tires laying around from one we junked, and the outer layer of rubber shredded itsself on the cutlass's front tire . And I don't have a job at the moment so it was ether cigaretts or have a shop change it lol so I just did it manually with two flat tip pry bars.
Old Aug 18, 2012 | 12:00 AM
Man you learn alot from old timers. And I know how to inspect tires for a bad belt..ect. People have been doing it for years that way. It doesn't hurt them. I have probably done about 25 of them manually in my time. Never had problems from it.
Old Aug 18, 2012 | 08:13 AM
bdub217's Avatar
We didn't hurt the rubber, we let the air out first, then drove up on it with the car and bounced on it to get the seal to pop. then we pried it off the rim and slapped the new one on BY HAND. (no pun intended) And why does it matter if we hurt an already screwed up tire??? The tire we put on was new....
Old Aug 18, 2012 | 04:09 PM
Exactly
Old Aug 18, 2012 | 05:10 PM
LOL, go get your tires balanced! Nothing like old fashioned back yard mechanics! I agree it does not matter about the old tire.
Old Aug 18, 2012 | 06:45 PM
lol ok will do!
sdfsd
Drivetrain/Differentials
Jul 24, 2015 03:52 AM
455man
Wheels and Tires
43
Jun 13, 2012 02:50 PM
krosser
Jun 18, 2011 12:18 PM
fritz442
Aug 7, 2010 07:10 PM
gillbates
Sep 18, 2009 10:57 AM
