converting
Old Jul 27, 2002 | 04:12 PM
72 Delta 88's Avatar
Question
My wife thinks I'm nuts, but I'm trying to save my '72 delta 88 from the junkyard. I'm trying to take this car that has too much undercarriage rust to fix and slavage as many parts as I can. I found a '72 delta 88 and was looking for some answers about transfering parts. Is the header panel, (head lights, parking lights, grill and bumber), interchangable from '72 to '74. Also looking to change the tail lights and rear bumber, as well as the dashboard. I guess I'm looking to convert a '74 back to a '72. Can any one tell me if these conversions are possible, I have found a '74 but haven't purchased it yet until I knew it could work.
Thanks in advance for any help,
72 Delta 88
Old Jul 28, 2002 | 11:23 AM
EdsDelta's Avatar
The Charter Member
Wink
You may be suprised to see the differences between the 2 years as far as body design. I know my 66 Delta woudn't match up to
Old Jul 28, 2002 | 11:24 AM
EdsDelta's Avatar
The Charter Member
Post
.. to a 68 Delta at all.
My best advice would be to mesure some of the bolt patterns on the parts you want to switch over. If they come close, then go for it. If they're not even close, then you're looking at a lot of work.
Ed
Old Jul 28, 2002 | 07:32 PM
EdsDelta's Avatar
The Charter Member
Post
Martine, check this out.. it's the radio you've been looking for!
EBAY
Old Aug 30, 2002 | 07:30 AM
biguke2001's Avatar
Post
I have a '71 olds 88 Custom sedan with a 455 2-barrel. I have found that 1971 -1973 fenders, headers, and hoods are interchangeable. Some trim features didn't follow, but bolts right up. In 1973 the bumpers changed, so did fillers, etc.. 1974 moved side markers around. 1975-1976 more changes in fillers and trim.
Headers off olds 98 will exchange easy too, using the same years as above. Pay attention to the hood as these may vary, but fenders are no problem.
Dash parts switch too.
I have a 1976 98 too, and have been hunting for parts.
good luck!!!
Old Sep 2, 2002 | 08:49 PM
martine's Avatar
Thumbs up
ed.good looking out.i lost the bid on that one.but have since won two am radios.but still looking for the am/fm 66 models.my prizes was both 65.thanks!!!!
Alocatelli
Aug 4, 2016 05:55 AM
Alocatelli
Dec 10, 2012 07:49 AM
taps442
Brakes/Hydraulic Systems
Jun 24, 2008 11:25 AM
z11375ss
Jan 15, 2007 07:00 PM
delkron97
May 18, 2006 08:20 AM
