What side of the master cylinder feeds what on a 1970 Cutlass with 4 wheel drum brake
Old Jan 31, 2023 | 07:54 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yes, I have the Chassis Service manual, not clear. I can go out and trace, really cold out. I am losing fluid from the front reservoir, so back brakes? All 4 wheel cylinders, master cylinder, maybe a hose and the two rear lines from the hose replaced with Nickel Copper lines. Thanks
Old Jan 31, 2023 | 08:16 AM
Front to the front, back to the back. And if you are loosing fluid but don't see a leak, suspect an internal leak between the front and back pistons in the M/C.
71supreme
Brakes/Hydraulic Systems
Jun 3, 2020 08:39 AM
DLP
Aug 15, 2018 05:42 AM
bigred1972
Apr 15, 2015 03:18 PM
texasred
May 1, 2012 08:48 PM
veltboy618
Jul 14, 2011 07:10 PM
