1967 442
Old Sep 26, 2022 | 03:27 PM
Bills67's Avatar
1967 442
I have a question? does it make a difference what gas cap I use on my 442? (vented or non-vented)
Old Sep 26, 2022 | 05:04 PM
I can't speak to whether or not your fuel system is entirely OEM stock, but the type of fuel cap which was installed OEM on the vehicle should be indicated in your 1967 CSM (Fuel and Exhaust System). My 1971 CSM demonstrates not only a picture of the positive two-step pressure vacuum type filler cap but two paragraphs describing its usage (pg 8-3).
Old Sep 27, 2022 | 05:03 AM
67s were stock vented.
Old Sep 27, 2022 | 07:00 AM
Oldsmaniac's Avatar
I am pretty sure the 67 caps were non vented as there are vent hoses coming out of the rear of the tank.
Old Sep 27, 2022 | 09:07 AM
So if you use a vented cap with a vented tank is that bad? Is there such a thing as too much venting?
Old Sep 27, 2022 | 10:09 AM
Oldsmaniac's Avatar
My common sense answer is no there is not too much venting but the location of the fill neck behind the license plate could allow spillage if the tank was full and jack-rabbit starts were had... At times though common sense with me is lacking.
Old Sep 27, 2022 | 12:40 PM
Bills67's Avatar
thanks for info! I have a "not vented" cap and 2 vent hoses coming off my gas tank!
Old Sep 27, 2022 | 01:08 PM
They consider those to be enough venting?
Old Sep 28, 2022 | 06:39 AM
Good point. I've ranted elsewhere on CO about how dumb I think that design is.
texxas
Jul 16, 2022 07:51 PM
shiftbyear
May 23, 2022 03:20 PM
dragline
Feb 18, 2022 10:07 AM
not2old
Jun 25, 2021 08:02 AM
